Question about Rotel RDV-985 DVD Player
Dvd player won't read Widescreen formatted disc all of a sudden. When I put in a standard formatted disc it works fine but w/a widescreen formatted one it just tries to load it and then says no disc.
Posted by kjjn on
Ralph Stephenson
    Scholar:
  • 159 Answers
Pull it's power plug out for 10 minutes then reconnect and switch on and see how it is then.
You may need to run Auto Set-Up again.
Posted on Sep 26, 2011
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
Jan 10, 2016 | Coby Televison & Video
Why does my philips portable dvd player not work
It is attempting to read the disc. Try another KNOWN GOOD disc. If you get the same error, try cleaning the lens using a lens cleaner disc or a dry q-tip. If no go, sorry, she's a gonner :(
Jul 20, 2014 | Philips PD7012 7" Widescreen Portable DVD...
My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Nov 14, 2012 | Televison & Video
    I purchased a DVD that states: Widescreen Format (Aspect Ratio 1.85.1) I'm unable to get 'widescreen/letterbox'. The movie shows up full screen or a 'stretched' view. All other movies I've...
    On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
    You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
    I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
    Jan 09, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
    Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
    The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
    Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
    The coby 7008 will play music perfectly-When I put in dvd it will read the widescreen producer credits and then goes to black. it will not read fullscreen at all but an exercise video it reads perfectly. i...
    I have a Coby TFDVD7008 portable dvd player. when i try to play a dvd it will say its loading then, after 1 minute later of waiting it stops as says bad disc. but it does that to all of our dvd players
    Aug 23, 2010 | Coby Tfdvd7008 Portable DVD Player
    Why my regular dvd player with widescreen movies does not fill my hd tv ?
    ok, There are 2 aspect ratio's for tv/movies. Widescreen Standard
    If you have a Widescreen TV, Widescreen formatted dvd's will fill the hole screen, Standard formatted dvd's will not fill the whole screen
    if you have a Standard TV, Standard formatted dvd's will fill the whole screen, Widescreen formatted dvd's will not fill the whole screen
    this is normal, check to see the format of the dvd you are trying to use.
    Jul 03, 2010 | Zenith XBV442 DVD Player/VCR
    Widescreen to full screen
    you can but it'll just come out in a larger widescreen picture. if the DVD is widescreen then that's how the film was formatted. and theres no changing it.
    Dec 06, 2007 | Symphonic WV806 DVD Player/VCR
    Camcorder Widescreen Recording Issue
    THERE IS REALLY NOTHING YOU CAN DO as your settings conflict with each unit connected
    Nov 13, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
    Rotel RDV-985 DVD Player Logo
    108 people viewed this question
    Top Rotel Televison & Video Experts
    Muntejaya Ginting
    Muntejaya Ginting
    deton8 von Splosion
    Tom Chichester
    Are you a Rotel Televison and Video Expert? Answer questions, earn points and help others
