Hello 0154, 0236, 0463, 0180, 0178, The One For All 4 Device Universal Remote Control is preprogrammed at the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable box, and an RCA VCR.To control devices other than the default brands,perform [1] Turn on a desired device (e.g.,VCR or DVD player) and, if NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program [2] On the remote control,press a device key once (i.e., VCR/PVR, NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) [3] Press and hold SET until the LED (red light) blinks twice, [4] Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly, NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter [5] Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works. If it still doesn't work, try
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0171, 0623
the following steps; otherwise skip this section:
applicable, insert media (e.g., cassette or disc).
before starting step 2.
DVD, CBL/SAT,or TV).
Combo, press CBL/SAT once.
then release SET.
the LED will blink twice.
the same code again.
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Since the EWC19T5 is a combination TV/VCR/DVD player, you can try the code 0821 for all three parts of the unit. This is only for the One For All URC-4021 remote. Otherwise, you should try the individual codes for an Emerson TV, Emerson DVD and Emerson VCR. (Note that Funai makes the Emerson brand electronics so Funai codes can also be tried.)
3021 codes (copywrite of March 2004):
Emerson DVD 0591, 0675
Emerson TV 0154, 0236, 0463, 0180, 0178, 0171, 0623
Emerson VCR 0037, 0184, 0000, 0121, 0043, 0209, 0278, 0479, 1479, 1278
The 4021 (2004, possibly 2008) has the following Emerson codes: TV/VCR/DVD 0821
DVD 0675, 0821, 1268
TV 0154, 0171, 0178, 0180, 0236, 0451, 0463, 1944, 1963
VCR 0000, 0037, 0043, 0121, 0184, 0209, 0593, 1278, 1479, 1593
I'm not sure when the EWC19T5 was built (except for being after 2002). However, if your TV is newer than your remote, you may need a new universal remote. The codes are limited to those for devices released 6 months or more before the remote was programmed.
One For All remote manuals and code lists are available here: http://www.oneforall.com/support/manual . Use the drop down menu to select Universal remote and then the model. You may need to change the country at the top to find your remote listed. The 4021 manual is here: http://www.oneforall.com/uploads/support/c22a0933bab24f44ae0cdcbd1cf1e2d8.pdf . The 3021 manual is available here: http://www.oneforall.com/uploads/support/00a1e876ce84e35c2c0351a407218d66.pdf .
Emerson TV manuals are available from Funai: http://www.funai-corp.com/support/manuals.aspx . Enter the model number in the search box since the units are listed in numerical and then alphabetical order by model. Emersons are several pages into the list. The direct link is http://www.funai-corp.com/6pdf/om/EWC19T5.pdf .
I hope this helps.
