Question about Precor C954i Commercial Treadmill
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Posted by erythrophobi on
ernesto cuadra
    Top Expert:
  • Precor Master
  • 12,223 Answers
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Posted on Sep 26, 2011
I have the 1750 Commercial Treadmill and the screen is "froze" on the program for the sd card or WiFi. When I push on the stop button or unplug and replug in the power it still is STUCK on that screen. ...
use this steps and fix it. God bless you
Step 1
Plug the power cord into a UL 1449 single-outlet surge suppressor and then plug the surge suppressor into an electrical outlet that is not GFCI-equipped if the power does not turn on. If the treadmill is plugged in and the power still does not work, make sure the key is in the console and that the Reset/Off circuit breaker has not been tripped. Press the switch to "Reset" if it has been tripped.
Sponsored Links
Gym Equipment Choose from 1M+ Verified Suppliers. Contact Directly & Get Live Quotes! www.alibaba.com/Gym-Equipment
Step 2
Check the Reset/Off circuit breaker if the power switches off while in use. Wait five minutes and switch the button to reset. Check that the power cord is still plugged in securely; pull the plug out and plug it back in after five minutes. Pull out the console key and reinsert to see if the machine will turn back on.
Step 3
Place the chest pulse sensor tightly right underneath your pectoral muscles or breasts for it to operate properly. Position it lower or higher on your chest if it does not work properly. Wet the electrodes with a saline solution. Walk near the walking belt's center within an arm's reach of the console.
Step 4
Remove the console key and unplug the treadmill to loosen the walking belt if it slows when in use. Turn the rear roller bolts counterclockwise with the hex key 1/4 of a turn until you can lift the walking belt's edges 3 to 4 inches from the platform.
Step 5
Remove the key and unplug the treadmill to adjust the walking belt if it is off-center or slips when in use. Loosen the rear roller bolts with the hex key and reposition the walking belt. Tighten the roller bolts. Walk on the treadmill to determine if the walking belt is centered. If not, loosen the roller bolts again and make adjustments until the walking belt is centered.
Step 6
Recalibrate the incline system if the treadmill's incline does not adjust correctly. Press the "Incline" button and remove the console key. Wait a few seconds and replace the console key. The incline will automatically recalibrate by moving to the maximum incline level and then the minimum level.
Step 7
Press the "Stop" button for a few seconds to turn off the demo mode if the console display stays lit after you remove the console key.
Read more: http://www.livestrong.com/article/241157-nordic-track-treadmill-troubleshooting/#ixzz2geWlKdPR
Oct 02, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
I have a precor c956i and got error 27 on it, what can i do to resolve probmem? thank you
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Sep 27, 2013 | Precor C956i Treadmills with HR /...
New belt still slipping on my 9.45
Dear Sir:
Thank you by your request. I hope everything is fine with your family.
I will help you inmediately.
You have a mechanical problem, please review carefully!
    • 1
Checkthat the surge protector meets the specifications listed in the manual.
    • 2
Removethe key from the console.
    • 3
Unplug the power cord.
    • 4
Turnrear roller bolts 1/4 turn counterclockwise using an Allen wrench.
    • 5
Keepingthe walking belt centered, you should be able to lift each edge of the belt 2to 3 inches.
    • 6
Plugthe power cord back into the surge protector.
    • 7
Reinsertthe key into the console.
    • 8
Repeatthe process if, after the treadmill has run a few minutes, the walking belt isnot properly tightened.ercupa190_0.jpg
Thank you in advance, sincerely. God bless you.
If you need further assistance, please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Sep 27, 2011 | Precor C956i Treadmills with HR /...
What does error 29 mean on a precor C954i?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29
Apr 06, 2011 | Precor C954i Commercial Treadmill
My belt is over to one side to much is there and easy way to get it back in the middle
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Jul 16, 2010 | Proform Quick Burn Pro Treadmill with 12...
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
Jul 15, 2010 | Treadmill Doctor Weslo Cadence Dx10...
Belt is skipping
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jun 13, 2010 | Proform 325 Treadmill Walking Belt
I have a Proform 380 Treadmill. When the treadmill is on the belt rubs on the left side.How do I center the belt?
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 24, 2010 | Proform 380 CS Treadmill !
Belt problem
f the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD.Using the hex key, turn both idler roller bolts clockwise,1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 14, 2010 | Proform Sport 1000 Folding Treadmill...
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
Precor C954i Commercial Treadmill Logo
526 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
