Most motherboards if not all will provide you a beep code if there is no RAM on the memory slot.
To fix the issue you would have to determine if the point of failure is the RAM of the Slot on the board.
If you have an identical known good working RAM you can try putting that in the board and if the same symptom happens then it means the problem is the slot on the board but if it works the RAM is busted.
Sadly the only fix for this type of issue is to replace the faulty part. (RAM or Motherboard)
Hope this helps!
If you feel that my answers have helped you getting
solution to your problems then please give a vote.
Thanks.
