SOURCE: shure beta 58a mic dismantle
Musman4:
i have 58S, which should look very much alike.
if you can see a screw in a small recess near the tail (not the 2 screws over the switch), remove it.
it you do not find this screw, probably because you lost it, so the 3-pin socket came out. Also, there is a C shape insert, wriggle and raise it, it should pop out.
good luck!
pc-cook
SOURCE: new cable for my Shure Beta 58A Professional
I scored an old beta 58 but the 3 pin connector was missing. i bought another one but i don't know which wires to connect where. plus there are only two wires, is that right? I'm a bit of a noob but I like to try things myself :)
SOURCE: i HAVE A WIRLESS SLX 2 BETA 58A AND IT RATTLES AND
The most common failure is te connection with the battery. In that case you can bench those clips in the right position.
Regards,
Gerard
SOURCE: Is there a way to open up a Shure Beta 58A?
Once you remove the grill, there is a C-Clip that holds the cartridge down into the handle. Use some c-clip pliers to pull the c-clip out of the handle. The c-clip will remain around the post on the cartridge, but that's ok.
