Carrier 2 ton ac gas pressure detail
Suction [low side ] want around 50--55 #--high side varies as to heat load ---as to quantity that also depends on length of the lines -- small house shorter run from condenser to evaporator uses less freon
The quantity by mass varies from unit to unit. The factory charge is usually stamped/printed on the nameplate of the unit. As far as pressure goes, the pressure of a saturated refrigerant is directly dependent upon it's temperature- at 70 F the pressure of R-22 would be around 120 PSI- this is applicable to 1 # or 10 # of refrigerant.
2 ton ac gas filling pressure 75 or 95 sir
how much secton pressure window ac 2 ton sir
Can i knw what should be the gas pressure in 2 ton split ac
