Question about Music
Need adiagram for replacing 3 wire factory humbuckers with 4 wire seymour duncans
Posted by tim gardner on
Geoffrey
    New Friend:
  • 65 Answers
First make a diagram of the wiring as it is with the 3-wire pickups, in case you need to re-fit them in the future. Remove the old pickups and store them in a box with the wiring diagram.
Have a look here: http://www.seymourduncan.com/support/wiring-diagrams/ and choose the wiring diagram which is closest to your guitar. It doesn't really matter that you are replacing 3-wire with 4-wire. It will give you the opportunity to install series/ parallel switching for more sounds though.
Posted on Sep 26, 2011
Joe Patch
    Sergeant:
  • 336 Answers
These are for the seymour duncan JB pickup which uses an extra switch for a coil tap. If you tie the leads of the switch you can avoid using it in which it would become a normal humbucker.3_8_2013_7_29_41_pm.jpg
Posted on Mar 08, 2013
  • Joe Patch
    Joe Patch Mar 08, 2013
    There several switch options shown here, the first one shows red and white would short to ground when switched could work with red and white tied together and be a regular humbucker.
Guitar pickup wiring diagrams
That guitar features two single coil pickups when stock. If, however, you or someone else installed a 4 conductor humbucker in the neck and you want to access other tonal options, check out the Seymour Duncan web site- they have tons of easy to understand diagrams- you just need the soldering skills to make use of them!
Make your selections on this page and good luck!
Dec 08, 2013 | Fender Squier Classic Vibe Telecaster 50s...
Push pull guitar diagrams
check at seymourduncan.com...your humbucker needs to have 4 conductors in order to tap coils...which is what I presume you want to do with the push/pull...
relative pickup wire colors:
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=coil_splitting
now match the Fender colors to the Seymour Duncan wirs and check this out:
Music Logo
579 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
