Make sure Router and Printer are setup with DHCP. This will assign an IP to the printer. Once they are communicating, setup the printer on the computer with the IP address, and install printer drivers.
Hello, Thank you for posting your question in fixya.com.
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003. The error can be cleared in the service mode (doing a reset).
Here's what you need to do:
Press Additional Functions key Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it.
I hope this helps!
Please let me know if it doesn't work or if you need my help. Thank you very much.
Have a look at the canon usa site:http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17160#DownloadDetailActThis link should take you to the canon support page, let it load and it will come up with the driver download center.In the area titles "Driver/Software Selection"Use the drop down menu and select "Mac OS x"This will bring up a list of current drivers for the Mac.The most recent one for the your printer is:MP480 series Printer Driver Ver. 10.6.0.0 (Mac OS X CUPS)If there is also a problem with your scanner then you will also need:MP480 series Scanner Driver Ver. 14.8.1 (Mac OS X)Just make sure you look carefully before clicking the driver as there are also spanish versions on the list..I hope these help.Mike
i used a bit of strapping cable and slid it up between where the paper first goes into the printer from the paper tray and found there was a bit of paper there. that fixed the problem.
