Question about Sanyo DP50747 50 in. Plasma TV
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
eagle338
  • 4,889 Answers
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Posted on Sep 26, 2011
    Top Expert:
  • Sanyo Master
  • 76,582 Answers
Hello
Press the INPUT KEY after connecting cables to access the AV inputs. There is no need to tune to a blank channesl.
HDMI INPUT-2, and HDMI INPUT-3 jacks have identical functions with HDMI INPUT-1, having an additisional feature for DVI connection. Compactable video devices can be connected to either set of jacks.
Use HDMI (DVI) INPUT-1 to connect your DVI device, make sure you connect the audio out to the DTV's VIDEO-3 Audio IN.
The VIDEO-3 audio jacks are used to recive the audio from the DVI device. These video jacks cannot be used when a DVI device is connected.
DVI TO HDMI INPUT-1 JACK CONNECTIONS.
[1] Connect the set-top box (STB) output to DVI's HDMI INPUT-1. Check with your local electronics store for a DVI to HDMI Adpter Cable that matches your equipment and DTV.
[2] Connect STB Audio out to DTV's video-3 Audio In L/R.
[3] Press INPUT to select HDMI-1 to view the digital programme.
NB: Only the HDMI (DVI) INPUT-1 jack can accept a DVI [Digital Video Interface] connection.
HDMI INPUT-2/INPUT-3 JACKS CONNECTIONS.
[1] Connect the external equipments' HDMI output to a DVI HDMI input.
[2] Press the INPUT to select the HDMI-1 or HDMI-3 to view the digital programme.
If you feel any difficulty to get the programme viewed or doesn't get any HDMI signal at all, check all the connections; especially HDMI cable for any fault' Should use a high quality cable when HDMI is used. OK.
Jyackle5
  • 8,197 Answers
Turn the PS3 on then press the input button on the remote or on the tv till you get a signal.
Why do I have to go all the way through my tv hookup (HDMI 1,HDMI2 etc)to get sound. I just hooked up to directv and it used to work fine.
Sounds like the TV do not save the LPM (Last Position Memory). Contact the authorized service centre. If the main system control memory IC has any fault, this might happen. Electro help
Nov 18, 2014 | Sanyo DP26647 DP42647 DP50747 Remote...
How come when I hook up our ps3 to it in the hdmi cable it's fuzzy what is wrong/how can I fix it?
You have to find out what is causing the problem, The TV, The PS3 or the cable. Most likely its a bad connection, or incorrect settings less likely is a bad digital board in your TV.
Connect the PS3 to another TV, if the issue is gone the problum is with your TV, first I would try all the resoultion options in the TV menu and the PS3, if that does not work I would still try another HDMI cable if it still is not working connect another HDMI device to the TV if it also is not working the problem is with your TV
Jun 07, 2012 | Sanyo Televison & Video
What cable do i need to connect my laptop to my Sanyo DP50740?
Hello jaygee7414,
Sanyo DP50747 not support for D sub conection (PC in).
To connect PC in, you can use DVI or HDMI input.
Some Laptops already have HDMI or DVI out put. Like HP mini, sony vaio.
Or you can use s-video input.
Thanks.
Mar 21, 2011 | Sanyo DP50747 50 in. Plasma TV
I am trying to hook my pc to my tv but i dont know how can u help me
Hi you need to connect with a hdmi cable hope this helps please give thumbs up thanks
Feb 13, 2011 | Sanyo DP50747 50 in. Plasma TV
Problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
http://pcaudiohelp.com/fix-hmdi-sound-to-tv
Feb 25, 2010 | Sanyo DP50747 50 in. Plasma TV
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Trying to hook up my ps3
ok i have come acrost this problem with my ps3
turn the ps3 off plug all the cables in right and put the tv on the right video input now hold down the power button on the ps3 for about 30 - 60 secs or untill it beeps or you see it working
let me know if it works
PLEASE RATE thanks
Mar 27, 2009 | Sanyo DP26648-R 26 in. LCD TV
42" Sanyo HDTV with 3 HDMI Inputs
Everybody is having problems with sony products and HDMI cables. It's on a lot of forums. So, your not alone.
Most of the solutions are:
1. Unplug your TV for 30 mins.
2. Plug TV back in and put it on HDMI for PS3.
3. Hold down the power button for 10secs on the PS3
That should solve the problem.
Feb 17, 2009 | Sanyo DP42746 42 in. Plasma Television
PS3 or LCD TV?
when the ps3 is in standby hold down the power button for over 4 seconds, it runs the optimal screen settings page. hope this helps
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Sanyo DP50747 50 in. Plasma TV Logo
Top Sanyo Televison & Video Experts
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
