Question about Samsung WF328AA Front Load Washer
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic test I can run on the machine before I start ordering/installing random parts? Machine is only 2 years old :(
Posted by mom2mikel383 on
  • mom2mikel383 Sep 28, 2011
    We've done all of that -- I'm wondering if there is a way to tell if the drain pump is the problem *before* I buy the part and then find out it's not the issue.
    Thanks.
Kevin White
  • Samsung Master
  • 1,902 Answers
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Posted on Sep 25, 2011
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
Nd on screen will not spin
How to fix a Samsung Washernd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Nov 10, 2012 | Samsung WF337AA Front Load Washer
Where is the drain filter on a samsung front loader? I am getting a nd error when I removed the hose from the pump, water came gushing out of the pump. Before I removed the hose, I made sure that the...
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump, located inside the bottom front access panel of the unit. Please get back to me if you have any other questions.
Kevin
Oct 04, 2011 | Samsung WF328AA Front Load Washer
My samsung WF209ANW front load washer keeps giving me "ND" error. we have cleaned the debris filter and cleared out all hoses. What is my next step? How can I tell if the drain pump needs to...
Unplug the unit. You should be able to locate the service manual which is located under the top panel this is what we use when a servicer comes to your home so you can at least try using the manual to help you locate the problem
Sep 25, 2011 | Samsung WF209ANW 40 cu. ft. Front Load...
Tried washing an old rug and the backing crumbled in my Samsung WF209ANW front loading machine -- now the machine won't drain because I assume it's clogged with the debris. We cleaned the debris...
You will have to clean out the large black hose on the bottom of the tub. The only way to get to it is to remove the top cover from the washer then remove the front of the washer, after removing the front you will be able to reach in and remove the hose and clean out the rubber backing. You can try it from the back of the washer first and may have some success but from my experience you will have to go from the front maybe both. Good luck and have some towels ready to catch the water.
Nov 26, 2017 | Samsung WF209ANW 40 cu. ft. Front Load...
Samsung washer keeps reading ND. Have manually drained the washer, cleaned all the hoses out. Found a coin, removed it, washed a blanket and the washer worked fine. However when doing another load, again...
Try following the steps here:
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=4&PROD_SUB_ID=864&PROD_ID=866&AT_ID=149972
You will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation. If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced.
I hope this information helps you. A 4-thumbs up rating is greatly appreciated. :)
Jun 07, 2011 | Samsung WF209ANW 40 cu. ft. Front Load...
I have a ND code on my samsung front load washer
ND error in your Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Apr 13, 2011 | Samsung WF328AA Front Load Washer
I have an error code of nd on my washer
If your washer is beeping, and the display is flashing "Nd", your debris filter may be clogged. To check for a clogged debris filter, goto back of machine, look for little door at bottom remove cover and remove filter and clean
Dec 19, 2010 | Samsung WF306BHW High Efficiency Front...
Samsung washer front load willnot rinse - no water coming out of hose to drain. E2 shows up
Hello,It is drain pump error. Possible solution:
• Clean the debris filter.
• Make sure the drainage hose is installed correctly.
If wont help you need to look in drain pump/wiring
More information about error codes here:
http://downloadcenter.samsung.com/content/UM/200411/20041124151342484_B1515-01527B-0603.pdf#search=%22samsung%20big%20wash%20b1415j%22
Thanks
May 31, 2010 | Samsung WF337AA Front Load Washer
Samsung WF328AA Front Load Washer Logo
1,046 people viewed this question
Top Samsung Washing Machines Experts
Marvin
Marvin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
