Question about Sony KP-53S65 53" Rear Projection Television
Burnt out EY34 - Sony KP-53S65 53" Rear Projection Television
Posted by peter lally on
  • SD Tech
    SD Tech Sep 25, 2011
    is it a tiny blue capacitor?
SD Tech
    Top Expert:
  • Sony Master
  • 14,553 Answers
EY34 is a location near a small blue capacitor that commonly burns up; Location number for the cap should be C514 and the values of it are 1,000 pf (pico farad) at 2 KV (2,000 volt rated).
Often if it is burnt it is the only problem and both Hitachi and Sony used the same identical part in several of their sets.
Let me know if you have questions.
sd tech
Posted on Sep 25, 2011
WHAT MAKE FIAT PUNTO 1.2 16V BURNT VALVE AND AFTER I BOUGHT ANOTHER NEW VALVE ITS BURNT AGAIN WHEN I TRY TO START
Burnt Valves are due to combustion gases aka your fuel and air mixture leaving their seals.
NASA went to the moon using orings to protect our astronuaghts lives.
Your valves use orings too, if those arent any good their gunna get burnt.
Nov 07, 2017 | Fiat Cars & Trucks
Juicer does not turn / rotate. Does this mean the motor is burnt out ?
It could mean burnt motor, but it could mean that it's simply got gunk in it, and it needs cleaning/lubricating. You'd have to take it apart to tell. A burnt motor has a very specific smell. If you take it apart, and there's no burnt smell, likely cleaning and lubricating will fix it.
Jun 10, 2015 | Braun MPZ-22 Juicer
How to gt rid of burnt smell inside the microwave from burnt popcorn
Wash with baking soda wipe out clean then wipe down with vinegar
it will eventually go away.
May 17, 2014 | Microwave Ovens
After unboxing and setup genpower 305 will not start
Hi and welcome to FixYa, I am Kelly
The generator has a low oil level sensor. Make sure the oil level is FULL all the way to the point oil comes out of the oil fill port when you add oil. If after your sure it is full of oil it still does not start then disconnect ONE wire from the oil level sensor and check for spark.
There is a model number on a data plate that begins with "PM" like this:
PM0435005
This model came as a manual and an electric start so the model number is important. The engine on this model is a Subaru engine and my experience with Subaru engines it that the low oil level sensors are extremely sensitive to even the slightest drop in oil level. (Good engines though!)
There should be a fuel selector that you need to turn ON and a Choke lever that you PULL and then push in upon start.
This should be and EH34 or EY34 engine.
Thanks for choosing FixYa,
Kelly
Aug 28, 2011 | Coleman Powermate Premium Plus 6250W...
My dvd player on recognizes original dvds but wont read any burnt dvds...WHY???
most of the laptop dvd drives have slower reading speed(about 2x) and writing speed(about 24x) compare to desktop pc's(about 8x and 52x respectively).
ur problem might have occured if the writing speed by which the cd was burnt might not be compatible with ur dvd player.
try playing dvds which were burnt using laptop dvd writers.
also try changing the modes in which the dvds are burnt.
Jun 19, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
I have HP Compaq nx7300, its charging ICs burnt
h18000.www1.hp.com/products/...div/12614_div.HTML
Jul 09, 2009 | HP Compaq nx7300 Notebook
XBOX 360 won't play burnt games
You need to have your console modded in order to play burnt games.
Visit: www.xboxmod.info
They can mod it for you and you will be able to play burnt games!
May 21, 2009 | Microsoft Xbox 360 Console
Factory cd player wont play burnt cds
A '96 CD player can't see newer burnt Cd's. Found that out with my '99 Chrysler.
Feb 26, 2009 | Phase Linear UDV9010 Car DVD Player
PS2
What it is, is from it playing on any burnt movies so now it won't play factory burnt discs only home-made burnt discs, try the movie on a home-made burnt disc. If nothing you can get a DVD player for like 20 bucks at wal-mart.
Apr 04, 2008 | Sony PlayStation 2 (PS2) Console
Sony KP-53S65 53" Rear Projection Television Logo
77 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
