SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
I imagine that the oil tube and or drip hole for the chain is plugged up. Remove the bar & clean up all the wood chips, etc to see if the bar oil is working. It can also be the hose or tank connection. Rick
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
SOURCE: stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
SOURCE: what kind of oil is used on the bar chain?
You will probably have to clean the oil orifice on the bar, if this does not do it you will probably have to clean and maybe rebuild the oil pump.
SOURCE: not much oil on poulan chain saw bar
there is some debris blocking from entering the bar and when sits it seeps out,clean bar and are under chain cover
