Question about Bunn GR10 Coffee Maker
My Bunn Coffee maker is leaking water from the bottom.
Posted by Judy Reynolds on
RJ Keck
    Novelist:
    Scholar:
  • 166 Answers
I had the same problem. On mine (and probably yours) the problem was the seal between the (upper) plastic water reservoir and the lower (metal) heating reservoir. No replacement seal is available.
I fixed mine by coating both sides of the old seal with aquarium grade clear silicone sealer - available at pet supply stores. Just a light (1/16") coating is all that's required. Carefully re-assemble and allow the sealer to cure for 24 hours.
I did that over a year ago, and it hasn't leaked a drop ever since.
Posted on May 26, 2014
5 Related Answers
atbsmmom
  • 189 Answers
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Posted on May 19, 2010
Toddman6
  • 8 Answers
SOURCE: My Bunn coffee maker is leaking water
The fill Tank is plastic and degrades over time. I bought a large rubber washer from local plumbing store to fill the void and seal the leak. The problem has returned and I need to replace the water fill tank completely. If possible??!!!. When to take the top of you will see a large screw with a hole in it, that is were the leaks occur.
Posted on Feb 21, 2008
Anonymous
SOURCE: my bunn coffee maker leaks
Experiencing same problem. Appears there may be a recall depending on your model and production date. I suspect it is the small seal washer where top fill tube attaches to the top of the tank. Water leaking here would flow done inside the round steel body and leak out bottom.
Posted on Aug 18, 2008
Gord Thurston
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Bunn 10 cup home coffee maker
It sounds like a seal/gasket is defective causing it to leak. Please locate the model and date code on the bottom of the brewer and contact customer service for troubleshooting and replacement options.
Feb 05, 2010 | Bunn 10 Cup Home Coffee Brewer
My bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Oct 24, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Apr 29, 2009 | Bunn 10 Cup Home Coffee Brewer
Jan 12, 2009 | Bunn VPR Coffee Maker
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Bunn GR10 Coffee Maker Logo
948 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
