Watches Logo
Question about Watches
How to change the date on a Mingrui WR30m watch and also the day setting unless these are corordinated?
Posted by petermagu438 on
Anonymous
    New Friend:
Keep on clicking on mode until it comes up with the seconds flashing. Then click on reset 5 times until the day is flashing. Then click on start until the day changes to the day you want! :D It worked for me
Posted on Jan 27, 2013
ahmed
    New Friend:
I just kissed it
Posted on Sep 13, 2013
3 Related Answers
Anonymous
SOURCE: Changing the DAY on this analog watch.
Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
I see that light bulb going off and you whispering "why, of course!"
Posted on Apr 03, 2008
Anonymous
  • 4 Answers
SOURCE: Seiko Diamatic Day Date Automatic Watch No: 219050
I have a Seiko Diamatic 780632. To set the day and date, pull the crown once and wind it upwards (away from you) to set the date; winding it downwards (towards you) will set the day. To set the time, you have to pull the crown twice and wind it towards you.
Posted on Nov 14, 2007
Anonymous
  • 14 Answers
SOURCE: Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Posted on Dec 01, 2007
My Watch is showing military time but i want it to show in the 12 hr clock
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
http://www.fixya.com/support/t6812987-change_timex_wr30m_from_24_hour_12
How do change my timex wr30m from 24 hour to 12 hour display
Mar 21, 2018 • The Watches
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
1helpful
I have a Mingrui company sportswatch.But the instuction paper is not fot my watch.It is WR30M
Call the company and see if they will send the paper work you need to your house.
Jan 02, 2013 • Watches
4helpful
How do I change the day on my Timex WR30M Easyreader Indiglo watch. I can change the date, but not the day of the week. Help....
When you bought the watch, did you find a little manual in the packaging? The manual has all the info.
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
Hope it helps.
Thank you for using FixYa.
5helpful
On some analog Timex watches with a day/date window there are only two "pull-out" positions on the stem, one for changing the date and one for the time. To change the day you need to pull the stem all the way out and crank the hands through 24 hour periods until you get the day correct. Be sure that you have the correct AM/PM setting (if you are setting the watch after noon you need to advance the hands another 12 hours so that the day changes at midnight)
Sep 07, 2008 • Watches
14helpful
3answers
Dec 03, 2007 • Watches
Top Watches Experts
Marvin
Marvin
john h
Are you a Watch Expert? Answer questions, earn points and help others
