Koss KS4102 System Logo
Question about Koss KS4102 System
Need a manual model ks4102 - Koss KS4102 System
I have a koss ks4102 home theater system, i can not get the tv sound to play through the home system speakers
Source the TV-related audio from the Cable Box,. Treat it like any other audio device.
My remote control for Koss dvd player [KS4102] doesn't work. how can find another remote for the player
1)take the remote & check in electronic market (or)u can get universal remote.
Cannot find dvd code for my koss dvd player
the three digit codes are 216 or 573
1helpful
Koss ks4102 pal/ntsc output
try to unplug the system for about 20min to see if it will reset the system
Dvd's
DVD-R
DVD-RW
DVD+R
DVD+RW
CD (Audio)
CD-R
CD-RW
S/VCD
There ya go! Easy info. Have a good one. :)
Cyryl
Koss Ks4102 video problem
You have chosen the progressive scan option. In this option you will not get a composite video out to your TV using a single cable. you need to switch off this option by connecting the DVD player using three single cables namely Rr, Yy, Bb. this is possible only if you have this input option on your Tv. once you do this you will be able to see the display correctly and do the changes of switching off the progressive option. refer to the manual it is explained
3answers
Koss KS4102 audio delay problem
You can get the update file from here. http://www.kevinschaefer.net/upgrade.zip. Good Luck and let us know how this turns out for you.
Whine
i have a koss KS4102 system also and mine does the same thing. its done it for almost 2 yrs now. ive taken it apart and noticed that the sound is coming from under the heat sink. im not an expert at home audio, but my best guess is its either the amplifier going out, or some kind of processor. but i do know from past experience that its probably going to be cheaper to buy a new receiver, rather than paying a pro to fix it, if it can be.
Problem with surround working with just the t.v. on
What type of plug from the TV are you hooking up to the sound system? Its has to be a HDMI or a scart. If its not and your using the rca red and white. The reciver has to be on the synth surrond setting or look in the owners manual, it will tell you what setting the reciver has to be on when using a non surround set or hookup
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Marvin
Marvin
Lawrence Oravetz
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
