SOURCE: I have a Th-50PC77U that
& blinks is sc or,sd or ,su board or all 3. Disconnect the ac cord. remove the back cover. on the left are 2 thin boards with flat cables that connect to the panel. these 2 boards are the SD and SU boards. They are connected to a board to the right. This the SC board or Y sustain board. Disconnect the 2 wie plug that connects this SC board to the power board in the middle. Examine the sqauare ics on the SC and SU boards on the rt side. Look for a pit or burn mark on one of the ics. If you see one then this board is bad. Disconnect this board from the SC board remove connectors on the rt and also remove the all the screws on this board. It should now be hanging free only by the flat cables on the rt. reconnect the 2 wire cable from the SC board to the power board. Plug in the set and power on. If set turns on the that board needs replaced. You will see 1/2 of picture. If still won,t turn on then disconnect the ac cord and the 2 wire conn from power board to SC board. disconnect the other board on the left letting it hang free. re connect SC to power board,plug ac cord in and turn on. If set now will turn on then Replace that board. If stiil won/t turn replace the SC board.
SOURCE: Panasonic TH-50PC77U will not turn on. Are there
Hi bhlewis116,
Yes, the power supply board(where the power cord's directly connected) has fuses. It is a multicolored or white ceramic fuse.
White ceramic fuse
multicolored ceramic fuse
To check it on the power supply board, you have to take off the rear cover of your TV. Let the unit unplug from the outlet for 1 hour to drain the voltages from the board before you do the repair.
See the location of the fuses on the picture below.
Check its continuity using the multimeter. If you've found an open one, replace it with same current(ampere) rating that is printed on the fuse itself or on the board.
Jdvillanueva
