Question about Learning Curve Toys Thomas the Tank Engine Track Rider
How long do you charge the battery on the thomas sit and ride one for
Posted by w_robinsonuk on
Battery will not charge
Do you mean it discharges while riding, or after it sits?
If while riding, then the charging system probably isn't working.
If you mean while sitting, if it's the original battery (2007), the battery probably needs replacing.
Jan 20, 2014 | 2007 Harley Davidson FLHX Street Glide
My Thomas 6v Ride -On Train works, but VERY slow. It sounds like its really struggling to go. I have TWO fully charged batteries so I know its not the battery. Everything else on it works great...
It sounds to me like your battery needs to be replaced. The batteries lose their ability to hold a full charge after some time (especially if they've sat for a long while without a charge). You can get the battery tested at a trusted shop, but it might be more econimical to just replace the batteries with fresh batteries and see if that solves the problem. New batteries will charge much better and hold the charge much longer.
Sep 23, 2013 | Peg Perego Gaucho Superpower
My Thomas the tanks engine ride on won't hold it's
check the charger with a multimeter and make sure that its putting out the correct amount of volts
Jun 09, 2012 | Toys
Battery won't charge when riding is it my voltage
If the cells are dead in the battery, it will never charge. You can go to Autozone and they will test it for free. The question would be if the battery is dead, why?? Are you just starting to ride after last season? How long has it been sitting? If sitting a while, the battery may just have died to age. If you are driving it all year, have the alternator/charging system checked
May 24, 2011 | 2002 Harley Davidson FXDL Dyna Low Rider
I have the Peg-perego Battery Operated Thomas the tank engine Ride-on. We bought it in 2006, used it a couple times...put it away bc my son was afraid of it. now my other son wants to ride it. When we...
I would check the battery voltage with a multimeter if possible. Battery should read at least 6 volts. Most likely the battery is too old to take a charge if it’s been sitting unused since 2006. I’d replace the battery first and then go from there.
Oct 07, 2017 | Learning Curve Toys Thomas the Tank Engine...
Thomas train shows as fully charged however when trying to use it, music starts but then a clicking noise and train doesnt move
the music is run by three aaa batteries so that will work no matter what, did you reconnect the battery to the vehicle after charging it
Jun 25, 2010 | Peg Perego IGED1084 Santa Fe Train
Is the white wire supposed to be connected to the engine?
it sounds likely the clip is supposed to hook to the white wire but thats just my hypotheses
Oct 02, 2009 | Toys
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 | Toys
Learning Curve Toys Thomas the Tank Engine Track Rider Logo
927 people viewed this question
Top Learning Curve Toys Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Learning Curve Toys Toy Expert? Answer questions, earn points and help others
