Flashing means you have to program the phone firmware,this is use when you have software problem,issues,need to upgrade,update or change the language particularly on your country's usage.To make this possible,visit my TIP and it will guide you on how to program your phone firmware perfectly by yourself.
TIP ON HOW TO UPDATE BLACKBERRY FIRMWARE
Good Luck....
Warning : Do not enter
any wrong unlock codes on your Blackberry Curve 8310 mobile phones. If
you enter over a certain amount of wrong unlock codes on your Blackberry
Curve 8310 mobile phone, your phone may get hard locked and sometimes
become unusable.
1 - Switch on your Blackberry Curve 8310 with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry Curve 8310 keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry Curve 8310 will now be unlocked.
That depends. Where did you hear that at?
