Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
Posted on Sep 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought a barely used second hand Saeco Vienna superautomactica. I cleaned all the parts. when try to prime it, the second greenlight will turn on after a couple minutes, the machine make some noice, but no hot steam came out, tried to make coffee, it will grind, but no coffee came out, what it the problem? Thanks a lot
Anonymous
Level 2:
Scholar:
  • Expert 115 Answers
  • Posted on Sep 25, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
115
Questions
0
Helped
86366
Points
218
Hi, Try removing the brew unit and cleaning it. Its been sitting, so i would think that your brew unit has a blockage. Dazza
1helpful
On Vienna Deluxe after the beans are ground and ready to drop the espresso shots, nothing comes out and the red light goes on? I shut the unit off for a minute or so, turn it back on and it works ok, but...
Solid red light is a ventilate light.. Try Priming the machine to see if the light goes away.
Something may be in the flow meter. Its the while device between the water tank and the pump of the machine. You would have to open the machine and clean out the flow meter.
Also, if you haven't descaled the machine already, I would start there.
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
2answers
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
1helpful
I just changed the boiler in my Saeco Vienna coffee machine, but I have a dought, should I fill it up with water before turn it on? If so, how do I do it?
HI
When you first turn the machine on, push the water button and open the knob on the right. It should take about 30 seconds to a minute to get water. If it is taking longer turn it off and let it set for 30 minutes, then try again. If the pump sounds louder than normal, turn it off and get you priming tool.
No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
2answers
Vienna superautomactica found a spring
That spring can fit in many places:-(
I put a blowprint of the brewingunit here.
2answers
Saeco Vienna Deluxe
http://cerinicoffee.com/Saeco_User_manuals_free.asp
6helpful
3answers
Saeco Vienna: water does not go through to the main unit
I had the same problem and got on the Saeco US website and talked to an online support person. She downloaded me a couple of pages of "fixes", I tried them and they worked! You have to take the two screws out of the brew group, remove the spring and a little clear plastic ball. Then clean out the hole thoroughly. I stuck a toothpick up into it from underneath to clean out the coffee that was stuck in the hole. I then put it back together and now it works perfectly.
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
