Question about Heartland 3110 Top Freezer Refrigerator
Our heartland fridge icemaker slowed down and eventually stopped making ice. there are ice cube in the tray but it does not cycle, thoughts? thanks!
Posted by jimwely on
Leo Ponder
    President:
  • 3,773 Answers
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 27, 2011
Reset the ice maker back to making ice again
Turn the water supply off to the fridge, make sure the bailer wire (ice level bar) is in the down position. let the Ice maker run thru its cycle. When the cycle is complete the fingers that push out the cubes should all be down. Unplug the fridge for about 5 min. During this time turn the water supply back on. Plug the fridge back in and let it run thru a few cycles. This should reset the icemaker cycle. As a note: you should be able to hear the water turn on with a solid thump as the valve opens to fill the cube trays inside the icemaker.
Sep 18, 2014 | Samsung Refrigerators
Icemaker on subzero 650 slow
check for water flow at water valve or replace water valve
Dec 09, 2013 | Sub-Zero 650 / O Bottom Freezer...
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
Fridge freezer, water inlet pipe keeps warming up
The home icemaker's predecessor was the plastic ice tray. It's fairly obvious how this device works: You pour water into a mold, leave it in the freezer until it turns to a solid and then extract the ice cubes. An icemaker does exactly the same thing, but the process of pouring water and extracting cubes is fully automated. A home icemaker is an ice-cube assembly line.
Most icemakers use an electric motor, an electrically operated water valve and an electrical heating unit. To provide power to all these elements, you have to hook the icemaker up to the electrical circuit powering your refigerator. You also have to hook the icemaker up to the plumbing line in your house, to provide fresh water for the ice cubes. The power line and the water-intake tube both run through a hole in the back of the freezer.
When everything is hooked up, the icemaker begins its cycle. The cycle is usually controlled by a simple electrical circuit and a series of switches.
At the beginning of the cycle, a timed switch in the circuit briefly sends current to a solenoid water valve. In most designs, the water valve is actually positioned behind the refrigerator, but it is connected to the central circuit via electrical wires. When the circuit sends current down these wires, the charge moves a solenoid (a type of electromagnet), which opens the valve.
The valve is only open for about seven seconds; it lets in just enough water to fill the ice mold. The ice mold is a plastic well, with several connected cavities. Typically, these cavities have a curved, half-circle shape. Each of the cavity walls has a small notch in it so each ice cube will be attached to the cube next to it.
Once the mold is filled, the machine waits for the water in the mold to freeze. The cooling unit in the refrigerator does the actual work of freezing the water, not the icemaker itself. The icemaker has a built-in thermostat, which monitors the temperature level of the water in the molds. When the temperature dips to a particular level -- say, 9 degrees Fahrenheit (-13 degrees Celsius) -- the thermostat closes a switch in the electrical circuit.
Closing this switch lets electrical current flow through a heating coil underneath the icemaker. As the coil heats up, it warms the bottom of the ice mold, loosening the ice cubes from the mold surface.
The electrical circuit then activates the icemaker's motor. The motor spins a gear, which rotates another gear attached to a long plastic shaft. The shaft has a series of ejector blades extending out from it. As the blades revolve, they scoop the ice cubes up and out of the mold, pushing them to the front of the icemaker. Since the cubes are connected to one another, they move as a single unit.
At the front of the icemaker, there are plastic notches in the housing that match up with the ejector blades. The blades pass through these notches, and the cubes are pushed out to a collection bin underneath the icemaker.
The revolving shaft has a notched plastic cam at its base. Just before the cubes are pushed out of the icemaker, the cam catches hold of the shut-off arm, lifting it up. After the cubes are ejected, the arm falls down again. When the arm reaches its lowest resting position, it throws a switch in the circuit, which activates the water valve to begin another cycle. If the arm can't reach its lowest position, because there are stacked-up ice cubes in the way, the cycle is interrupted. This keeps the icemaker from filling your entire freezer with ice; it will only make more cubes when there is room in the collection bin.
This system is effective for making ice at home, but it doesn't produce enough ice for commercial purposes, such as restaurants and self-service hotel ice machines. In the next section, we'll look at a larger, more powerful icemaker design.
There are any number of ways to configure a large, free-standing icemaker -- all you need is a refrigeration system, a water supply and some way of collecting the ice that forms.
One of the simplest professional systems uses a large metal ice-cube tray, positioned vertically.
In this system, the metal ice tray is connected to a set of coiled heat-exchanging pipes like the ones on the back of your refrigerator. A compressor drives a stream of refrigerant fluid in a continuous cycle of condensation and expansion. Basically, the compressor forces refrigerant through a narrow tube (called the condenser) to condense it, and then releases it into a wider tube (called the evaporator), where it can expand.
Compressing the refrigerant raises its pressure, which increases its temperature. As the refrigerant passes through the narrow condenser coils, it loses heat to the cooler air outside, and it condenses into a liquid. When the compressed fluid passes through the expansion valve, it evaporates -- it expands to become a gas. This evaporation process draws in heat energy from the metal pipes and the air around the refrigerant. This cools the pipes and the attached metal ice tray.
The icemaker has a water pump, which draws water from a collection sump and pours it over the chilled ice tray. As the water flows over the tray, it gradually freezes, building up ice cubes in the well of the tray. When you freeze water layer by layer this way, it forms clear ice. When you freeze it all at once, as in the home icemaker, you get cloudy ice.
After a set amount of time, the icemaker triggers a solenoid valve connected to the heat-exchanging coils. Switching this valve changes the path of the refrigerant. The compressor stops forcing the heated gas from the compressor into the narrow condenser; instead, it forces the gas into a wide bypass tube. The hot gas is cycled back to the evaporator without condensing. When you force this hot gas through the evaporator pipes, the pipes and the ice tray heat up rapidly, which loosens the ice cubes.
Typically, the individual cube cavities are slanted so the loosened ice will slide out on their own, into a collection bin below. Some systems have a cylinder piston that gives the tray a little shove, knocking the cubes loose.
This sort of system is popular in restaurants and hotels because it makes ice cubes with a standard shape and size. Other businesses, such as grocery stores and scientific research firms, need smaller ice flakes for packing perishable items. We'll look at flake icemakers next.
In the last section, we looked at a standard cube icemaker design. Flake icemakers work on the same basic principle as cube icemakers, but they have an additional component: the ice crusher. You can see how a typical flake system works in the diagram below.
Like the cube icemaker design we examined in the last section, this machine uses a set of heat-exchanging coils and a stream of water to build up a layer of ice. But in this system, the coils are positioned inside a large metal cylinder. Water passes through the cylinder, as well as around its outer edges. The passing water gradually builds up a large column of ice surrounding the cylinder from the inside and outside.
As with a cube icemaker, a solenoid valve releases hot gas into the cooling pipes after a set length of time. This loosens the ice column so it falls into the ice crusher below. The ice crusher breaks the ice cylinder into small pieces, which pass on to a collection bin.
The size of the ice bits depends on the crusher mechanism. Some crushers grind the ice into fine flakes, while other crushers produce larger, irregularly shaped ice chunks.
There are many variations on these designs, but the basic idea in all of them is the same. A refrigeration system builds up a layer of ice, and a harvesting system ejects the ice into a collection bin. At the most basic level, this is all there is to any icemaker.
Mercedes Custom parts
Jun 05, 2012 | Kenmore Fridge Freezer Ice Pan Part...
I have an older fridge with the ice maker in the freezer, just dumps into tray below. Anywho, water leaks from the ice make everytime it fills into the pan below, making one giant junk of ice. Please...
you have to determine if its the icemaker mold that has a crack and therefore leaks, or if you water valve solenoid is not closing compeletly at the end of the cycle. to check this, turn the water supply off to the refrigerator, then lift the arm up to turn the icemaker off. wait 3-6 hours, in case it JUST cycled, turn the icemaker back on, and it should dump one last set of ice cubes. slowly pour 4-8 oz of water into the icemaker with a measuring cup. do you see that same drip? if you do, replace your icemaker, if you dont, replace your water valve.
Mar 17, 2010 | Refrigerators
Fridge makes clinking noise periodically throughout the day. It is getting worse and louder. It started after i put the ice cube maker back into action (i had it in the upright position to stop making...
If the noise is only heard when you activate the icemaker, then your problem is probably with the icemaker. Some icemakers make more noise than others. If it's unbearable, replace the icemaker.
Feb 19, 2010 | Whirlpool GB2SHDXTT 22.1 Cu. Ft. Gold...
Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Jun 22, 2008 | U-Line Icemaker
Water overran ice maker tray
It could be one of two things. The fill cycle could be too long causing the water to overflow or the icemaker may not be ejecting all the cubes out of the tray. A normal fill cycle is very short. Maybe 6 seconds long. So I would check and see how long the fill cycle is and when it stops check and see how much the tray is filled with water. I would also check and make sure that all the ice cubes are ejecting next time you hear it harvest.
Jul 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Frozen ejector arm
sounds more like the heater in the ice maker is bad. The cycles of the ice maker are: 1. water comes in to fill ice maker. 2. water freezes in ice maker making. 3. heater comes on to help ice release. 4. motor comes on to eject the ice and start all over again. if the heater doesn't come on the ice will not eject. replacing the icemaker is typically what needs to be done in this case.
May 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
Heartland 3110 Top Freezer Refrigerator Logo
203 people viewed this question
Top Heartland Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Heartland Refrigerator Expert? Answer questions, earn points and help others
