If it worked before and suddenly doesn't work now it could be a bad cable. kinks in the able can be a problem but also when you plug-in the cable be careful because damaging the cable end or the the cable port is easier than you may think.. first replace the cable with one that you know works on another unit ..if that doesn't work examine the ends carefully for anything out of the ordinary.. get a technician to take a look if something seems strange with the cable end or the port..DVI cables come in several flavors make sure your using the right one and don't force the cable in that could make matters worst and more expensive....good luck..!
