Question about Sony KDS-R50XBR1 50" HDTV
KDS-R50XBR1 sony repair manual - Sony KDS-R50XBR1 50" HDTV
Sonny Berry
  • Sony Master
  • 8,617 Answers
You can get the service manual by download link within minutes from the following link http://servicemanuals.vstore.ca/product_info.php/pName/kdsr50xbr1-kdsr60xbr1/cName/sony-manuals
Posted on Sep 25, 2011
I have a Sony KDS-R50XBR1. it worked fine last night, this morning however, it did not come on at all. it blinks green for awhile, then blinks red continuesly. what is wrong? please help.
The red blinks are a diagnostic tool. If you search this site for KDS-R50XBR1 you will see several problems and the area to look in to. the red blinks should be followed by a three second pause and then repeat. Just count the blinks after the pause and you should have a better idea of what is wrong. The service manual goes all the way up to ten blinks.
Feb 08, 2011 | Sony KDS-R50XBR1 50" HDTV
Please tell me what the part # is for the Ballast on the Sony 50" Projection TV Item: KDS-R50XBR1. Thank you!
Encompass Parts Distribution is showing PN#1-468-936-13 sub# 1-800-638-3328 I didnt see any in stock,You might want to Look on Ebay under Electronics/ TV Parts
Encompass does have Free service Manual for this Model.
Nov 10, 2010 | Sony KDS-R50XBR1 50" HDTV
Have a Sony TV modelKDS-R50XBR1 and after changing
Required optic block part number is A1148155A for KDS-R50XBR1, commonly calls light engine. Available HERE and HERE.
Click above links for price info.
Thanks.
Jul 30, 2010 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 optical engine problem
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 27, 2010 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Thanks.
Nov 17, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1, where can I buy the fan?
online look up sony kds-r50xbr1 or go to a TV repair shop.
Aug 25, 2009 | Televison & Video
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
SONY KDS-R50XBR1 3 Flashing lights...problem not the door
klchen,the lamp door is not mating with the safety switch on its' left side,or the switch is bad.JOE TV.
Apr 04, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 50" HDTV Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
