Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
Need operators manual for a haier dishwasher hdp18pa
Posted by Torrence on
laura_seel
    New Friend:
Www.specsserver.com/CACHE/FRWDAJEQUXIO.PDF Full downloadable manuel
Posted on Feb 11, 2012
4 Related Answers
orangehigh
SOURCE: need user manual
http://www.compactappliance.com/ownersmanuals/haier/HDP18PAownersmanual.PDF
here you go
Posted on Feb 24, 2008
Anonymous
GOT A AEG ELECTROLUX SENSORLOGIC 40660 AS A GIFT
WITH NO MANUAL. I DO NOT NOW HOW TO WORK IT
CAN YOU PLEASE SEND ME A MANUAL TO
R. PRETORIUS
P.O.BOX 128
DENEYSVILLE
1932
THANK YOU
Posted on Jul 23, 2008
Anonymous
  • 9 Answers
SOURCE: Haier Dishwasher hdp18pa - Power reset
Are you blowing a fuse or throwing a breaker? Either way there is a chance that no outlet you have chosen to test with yet is on a circuit with sufficient amperage-I had this with a microwave I recently had installed. If you have the manual, check for requirements regarding amperage. You then need to be sure you are using an outlet with amperage comparable to the requirements-this is on your fuse or breaker. If your requirement is, say, 20 amps, a 15-amp or less breaker or fuse is going to fail. I had to go to a 'clean' circuit from my garage with nothing on it to find out I did not have enough amps in my circuit. My solution was a dedicated breaker. Another option is to use my second option (which I did not need), to plug it into a gas generator with sufficient wattage/amperage. This ensures nothing else is on the circuit.
Failing all that, it could be the power supply for the washer, a circuit board issue, etc. Don't mess around if you don't understand electricity, though-it's not worth frying yourself.
Finally, if it worked ok before and this has just begun to happen, I'd tend to think it's an issue with the washer itself. Hope this helps.
Posted on Jul 07, 2009
Anonymous
SOURCE: Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Posted on Jan 12, 2010
I need an operators manual for this model dish washer. I bought it used and they did not have a manual
I was just signing off for the night when I saw this. You can download your user manual free from here:
http://www.haier.com/admin/en/product/upload/HDP18PA-UM.PDF
Click the link and the manual will open in a new window, you can then print it or save it to your PC for future reference by clicking "File" in the top left corner of the browser window and then clicking on "Print" or "Save As...". If you are unable to open the file, you will also need to download the latest version of Adobe Reader:
http://get.adobe.com/reader/
Regards,
BElectric
Nov 23, 2010 | Haier HDP18PA Stainless Steel...
Water is splashing back at me when I hook up the Haier HDP18PA shy?
1)If cycles not complete before opens(it will splash)
2)check any block in rinse arm.
Jan 08, 2010 | Haier HDP18PA Stainless Steel...
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Need user manual
R. PRETORIUS
P.O.BOX 128
DENEYSVILLE
1932
THANK YOU
Jun 12, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Feb 03, 2008 | Haier HDP18PA Stainless Steel...
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
159 people viewed this question
Top Haier Dishwashers Experts
Marvin
Marvin
Peter
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
