Question about Aastra Telecom Aastra 9417 CW Corded Phone
My answering service picks up after 3 rings....how do i extend the answer time to 6 rings or so?? I have the 9417 CW
Posted by declan438 on
Ian ruth
    New Friend:
  • 32 Answers
Ask your provider to change your voicemail to pick up in36 seconds instead of 18. Each ring is 6 seconds. Hope this helps
Posted on Nov 06, 2013
4 Related Answers
Anonymous
  • 84 Answers
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Posted on Feb 14, 2008
Anonymous
SOURCE: Need more time to pick up phone(disabled)
The phone does not have this facillity.However,switching the answer machine "OFF" allows me to lengthen the ringtone to 16 rings as on the Users Guide.
Many thanks for your interest,
Posted on Dec 29, 2008
Mark Egan
  • 1214 Answers
SOURCE: set answer machine on a kx-tga101s to pick up on 8 rings
From the manual, it doesn't look like you can reset the ring count with this phone set.
You can find the manual at www.panasonic.com
Reply back if you have any further questions, or feel I have missed something.
Posted on Feb 02, 2009
Anonymous
  • 60 Answers
SOURCE: Norstar M7310 phone doesn't ring and doesn't pick up calls
You need the set the line appearances on the station. this is done in config programming. Set you station to have lines to "ring and appear"
dan
Posted on Aug 01, 2009
My phone only rings 5 times before the answer function takes over. Is it possible to increase the number of rings?
The number of rings before your answring message picks up the call is controlled by your cellphone service provider. call in to your voice mail and then follow the instructions about going to options and setting. There should be a setting in there for the amount of rings to wait before answering the phone.
Feb 04, 2015 | Cell Phones
How do i extend the rings before the answer machine cuts in on my BT6500
Set the answer delay
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press (Calls) until Settings is displayed, press Select.
3.Press (Calls) to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use < or > to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Set the maximum message length
You can set the maximum length that an answer
machine message can be: 1 minute, 2 minutes or 3
minutes. The default setting is 3 minutes.
Select.
3. Press (Calls) to highlight Ans. & record and press
Select.
4. Press (Calls) to display Max. msg length and then
press < or > to select the length you want and
Billy from Hayward
It is in the owners handbook page 45 get it while the link last
http://www.shop.bt.com/content/uni2/documentation/8h3h/bt6500_user_guide.pdf
Jan 09, 2015 | Lands Phones
Extend ring time
this feature is set by your carrier. Call customer service and ask them to extend rings to 6 - 8.
Jul 26, 2014 | Motorola Cell Phones
Extend number of rings before answering machine
The 6041 isn't an answering machine. It will ring until you pick up, an answering machine or voicemail system picks up, or the caller hangs up.
Please refer to the documentation for whatever answering machine or voicemail system you have on your phone line. If you require further assistance, please add a comment to this question and specify the answering machine or voicemail system.
Dec 26, 2013 | Vtech Cordless 6041 Phone
How to adjust how many rings on answer machine
Since you declined to give the model of your VTech system, please enter it into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Nov 13, 2013 | Vtech Lands Phones
Our DECT2015 phone only rings 4 times and then stops.How cane I adjust the ringing time of our phone? Thanks Peter
Do you have voicemail or an answering machine? This is usually a sign that another device (fax, answering machine or voicemail service) is set to answer the call after 4 rings. You will need to lengthen to number of rings before the service/device in question picks up. (The method to reset this will depend on the service/device that is picking up.) Another possibility is a call forwarding service that is enabled at 4 rings.
I hope this helps. Please write back with details on the device that could be picking up for details on setting the number of rings. If you have voicemail or call forwarding, check with your telephone service provider to lengthen the number of rings before the service kicks in. (There are too many for me to know all of the providers instructions.)
Apr 16, 2011 | Uniden Lands Phones
Brother MFC 885 CW answering service malfunction
It was all a matter of pressing down the Digital TAD button down hard enough... o-:
Sep 01, 2008 | Lands Phones
Aastra Telecom Aastra 9417 CW Corded Phone Logo
111 people viewed this question
Top Aastra Telecom Lands Phones Experts
Marvin
Marvin
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
