On my men's classic wave, the stem is removed simply by pulling it out. It feels like it's requiring a lot of force, but it is designed to have resistance so that it's not pulled out accidentally when setting the time.
So to change the battery, you remove the 5 faceplate screws, remove the crystal and gasket, pull out the stem and then the whole face/movement assembly will pull forward.
NOT positive yours is the same, but that's how my men's Classic Wave is. Good luck!
Thank you for contacting FixYa.<br />
I would recommend you send your watch here:<br />
<a href="http://precisionwatchrepair.com/ebel/index.html">http://precisionwatchrepair.com/ebel/index.html</a><br />
Best regards.<br />
Jewel
Punch must be metal. Size of punch must be the same as the screw size. Punch must go into the hollow part left by the screw, so, when tapped, the screw end (nut) will come out from the opposite side to where screw came out. Start tapping lightly and go harder and harder till you see the ends coming out. Read my tip - it can help as well. Tools can be bought on Ebay.
Rate me, plz.
If you want to pay the premium for an Ebel strap then any Ebel dealer or an online source can provide that.
For a much more reasonable price, I would try a store that sells AND installs watch straps. Usually, only independant jewelers both sell and install these.
to change the batt on an ebel womans watch i simple. 1 take out screws from bezel. 2 lift off , make sure to keep rubber gasket in place. 3 pull out stem to the set position. 4 be very carefull not to bend / touch hands. 5 turn case upside down, and you will see the opp side from the winder drop out slitely. with your fingernail pull downwards gently on works, then when you have it out a little on that side, turn it back over. and continue to lifft up gently, 5 as you do so, start to rowtate the works counter clockwise. the stem is made to .bend / swivel and the works will turn upside down and lay back into the case. to protect the face while installing the batt. 6 when done gently lift the same way but rowtate clockwise. but make sure you grab sides of works and not the face. ( the hands are very delicate) 7 take the batt to a jeweler to replace you will never find a batt with the same number ( ebel made sure of that ) they want you to pay 140.00 to 240.00 for them to do it. but a jeweler can match it. now that said, once you take the bezel off, your ebel warenty is void. so 140 -240 or $5.00 your choice i have had meny watches over the years all with rubber gaskets and have replaced batts is some five times and the gasket are still fine. and a batt will last 3 to four years. five in 15 years could cost you $ 1020.00 in the long run. hope that answers your question.
Unfortunately it is not possible to do it yourself as special tools and skills are needed. You can bring your watch to the nearest watch repairer or find the nearest EBEL dealer here: www.ebel.com - Cached Note: sometimes it is not possible to repair or renew stretched links and replacement of band is necessary.
