Question about Black Diamond Oval Carabiner
Hello, I want to know what is CE 0299, is it an standard mark? if yes what are diffrences between carabiners that have UIAA standard & CE standard? what do you know about "EN 362:2004" & "12275:1998" standardes in such this productes?
Posted by hamid_shahab on
How do I get instruction manual for Hasbro bopit carabiner edition
Use google search and you can download the PDF from the results. This was previously answered for you.
May 20, 2015 | Hasbro Bop It Mini Carabiner Edition
Is there any diffrences beetween ytx7 a-b s battery & ytx9 b s battery?
Yes, the size.
YTX 7 is 6 Ah.
YTX 9 is 8 Ah.
Both are made in China.
Apr 17, 2011 | Factory bike Desert YR 250 Motorcycles
When setting timing on a 1992 honda accord what is the diffrence between the red and white mark.
The RED mark is the timing mark and the WHITE mark is for Top Dead Center for #1 piston.
Dec 27, 2010 | 1992 Honda Accord
Hello, will a radio from a differnt year Lincoln fit(into the space given) into the 90 Mark vii ? I would like to have a cd player.
should imagine so ,standard size hole for it ,with the right wiring adaptor plug you should have no problem
Dec 19, 2009 | 1990 Lincoln Mark VII
I'm sure that beefs and rodrigo have misunderstood vpbjo's problem: to wit... You have to disconnect the caribiner to load the gri-gri. If you drop it on the gym floor, that's ok. If you drop it half...
Straight from the Instruction Manual: This product is a belay device for
the leader or second on a rope.
It has been developed for indoor
wall climbing or for climbing
on well-protected sport routes
where anchors meet the UIAA
standard. It should not be used
for mountaineering or adventure
climbing.
Any modification is a unknown change in the devices individual load bearing rating, and a compromise in the safey of anyone who would be connected to said device at any time after the modification.
Jun 28, 2009 | Petzl America Grigri Belay Device D14
How do I take clean my Carabiners?
Typically, you'll only need to clean your carabiners by blowing any dirt or dust away from the hinge area. If any additional cleaning is necessary, then be sure to wash your carabiner in warm soapy water, and rinse it thoroughly. Once it is rinsed and dry, be sure to lubricate the gate area with a dry graphite, WD40 or other kind of lubricant. Using a dry lubricant will help to keep your carabiner clean longer, as dirty will not be readily picked up. Once the gate has been lubricated, be sure to wipe off any excess lubricant.
Dec 01, 2008 | Arc'Teryx Theta Ar Bib Women's
How should I pick my carabiners?
Depending on your style of climbing, you will want different kinds of Carabiners. There are basic types: your oval and D-shapes are your most basic Carabiners. Sometimes you'll want a locking Carabiner, especially for belay, or for anchors. Most Carabiners that you have will probably not be locking Carabiners. There are different types that are easier to clip. There's bent gates, straight gates, wire gates. It depends on your style and if you're weight conscious, or how durable you'd like them to be.
Which kind of carbiners shoul I use
The best carabiner shape for any kind of static rigging is a symmetric shape - oval is the best. Most carabiners are asymmetric "D" - which is stronger but will cause the line to shift when loaded - the oval shape is better because nothing will shift to one side of the carabiner when loaded. You could use standard aluminum carabiners or even locking ovals (Petzl and Omega make very nice locking ovals), but I would also suggest using steel carabiners - they are cheaper and stronger and since weight isn't an issue they are better.
Dec 01, 2008 | Black Diamond Equipment Primrose Climbing...
Diffrences between win 2000 & win 2003 ?
Hi Sir Nice quition see what is the diffrences between win98 and XP u know sir ''''''''''' see below
********* win2000server and 2003 diffrence men Security and advanced server Tools is their ok byy*********
Apr 18, 2008 | Microsoft Windows Server Standard 2003 for...
Black Diamond Oval Carabiner Logo
672 people viewed this question
Top Black Diamond Rock & Ice Climbing Experts
ray gallant
john h
rhodesworks
Are you a Black Diamond Rock and Ice Climbing Expert? Answer questions, earn points and help others
