Question about Stanley Garden
I have a Stanley MR77 rivet tool that I had to take apart to remove a bent rivet. Now I can't figure out how to reassemble it. Where can I get a manual, or drawing, for it?
Posted by rfrost137 on
4 Related Answers
Capt Rick
  • 81 Answers
SOURCE: took ISF-40 all apart to clean , now need drawing
If you forward your e-mail address I will send you an exploded view of the fryer with parts listing. What parts are you having trouble with ?
[email protected]
Posted on Jul 29, 2009
billandjo313
  • 22 Answers
SOURCE: Riveter doesn't eject the pin after rivet is seated.
If your pop riveter is the same as mine, after you install a rivet you must turn the tool over and spread the arms and the stem from the old rivet will drop out. I had one stem stick inside the tool, and had to disassemble the whole thing...if you have to do this, have a friend with you...you need 4 hands.
Posted on Oct 07, 2009
Testimonial: "Prompt, on-target advice. I very much appreciate it. You guys are great! Sincerely, Paul Schneiter."
Anonymous
SOURCE: Stanley MR99 Riveter I dissasembled to release a
How do I dismantle the spiral from the outer casing of a yankee screwdriver
Posted on Jan 13, 2010
mb50sa
phil cuzins
  • 80 Answers
SOURCE: i need to remove chain
Some tools do both riveting and removal, does yours? If you are unsure or not confident I would fit the usual joining link (should be supplied with the new chain) and take it to a bike shop and get them to rivet it. This would be far cheaper than buying the right tool, and you dont want the chain to come apart when riding.
Posted on Aug 04, 2010
Testimonial: "soound advice thankyou"
Stanley manual
First never take a tool apart if don't know what you are doing, second go to the Stanley web site and you can buy or download a copy of the one you need.
Mar 08, 2014 | Stanley Hand Tools
How to fix a grabber reacher?
I have a idea to help you .If apart ,you mean the rivets are missing? If this is the issue, find or ask a family member w/ a pop rivet gun.The claws that do the grabbing are stamped,labeled (L)-(R). Reassembling the Grabber w/ the rivet gun wouldn't be too difficult .I could fix your problem, if we were neighbors!
Mar 03, 2013 | Unger NN140 Nifty Nabber Trash Grabber 51"...
I have a stanley 99e. i took it apart ti change the blade, without paying attention, and now i can't re-assanble it properly. I can't find any instructions online.
Hi.
See here the Stanley knife disassembly. If you have a 99E there may be an additional plastic part that is not shown in the diagram. The plastic tab is located at the back of the blade.
Jun 02, 2011 | Stanley Utility Knife
How do you get the tyre of the rear wheel off a razor 300
Its not meant to be removed. Purchase a new one and save yourself some troubles. You need special tools to remove it. I highly recommend purchasing the wheel complete.
Sep 12, 2010 | Razor E300 Scooter
I need to remove chain and fit new but not sure about fitting riveted link as have always used a joining link. do i rivet new link using rivet removal tool ? many thanks Roger
Aug 04, 2010 | 2008 Honda XL 1000 V Varadero
Dec 29, 2009 | Stanley Hand Tools
MY STANLEY 61804 DOES NOT PUMP. THE PUMP HANDLE JUST POPS STRAIGHT DOWN EVERY TIME i TRY TO PUMP IT. ONLY USED 3 X. wHATS THE PROBLEM ???
the darker Seal has come off the plunger at the bottom of the unit , easy 5 min fix , just unscrew the allen keys at the bootonm take off the cover and remove the plunger , you'll see the plunger seal still inside you can fish it out with an allen key or similar tool clip it on again and reassemble
Oct 29, 2009 | Stanley Professional Backpack Poly...
Oct 07, 2009 | Marson HP2 Professional Riveter
STANLEY QUICK POINT BLADES...CAN'T FIGURE OUT HOW TO CHANGE.
There is a SLOT in the end of the knife. Simply insert the strip of new blages in to the slot and you are ready to go.
Good luck. :)
Apr 25, 2009 | Stanley Hand Tools
Garden Logo
374 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
