Mitsubishi WD-52825 52" Rear Projection HDTV Logo
A
Anonymous Posted on Sep 24, 2011
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to reset and a constant yellow blinking light with a quick green light then back when I hold reset. Maybe the ballest????
Sonny Berry
Level 3:
  • Mitsubishi Master 8,617 Answers
  • Posted on Sep 25, 2011
Sonny Berry
Mitsubishi Master
Level 3:
Answers
8617
Questions
Helped
1722002
Points
23750
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
1helpful
Hear a pop like a firecracker and then no picture
It is likely that the bulb has failed. The bulb can be removed as an assembly from the rear of the unit. Carefully inspect the lamp and confirm that the glass bulb has failed. the pop could be the bulb fracturing. Careful for broken glass. Suggest that you buy a direct manufacturing equivalent. I have found they are the brightest.
26120369-qhrtjxzbaepf4lgqc41ptsvr-3-0.jpg You can buy just the bulb or the whole lamp assembly as pictured above. I recommend buying the assembly
\The link is from the owners manual providing the instructions to replace lamp.
http://www.manuals365.com/swf/mitsubishi/638-c10_bib.html?page=28#manual
Hope this has helped?
Tv won't power on anymore. i get a solid red light. why?
Solid red light means the lamp has failed. Try replacing the lamp first. Mitsubishi DLP TV Bulbs
These folks have the proper lamp you need and have a 6 month warranty
Mitzibushi Tv model WD-65638 no picture no sound
Youre lamp has failed. you need to replace the lamp. Refer to the manual to see how to replace it. It only requires 2 or 3 screws on the back to be removed. Please check the manual.
You need a 915B441001 lamp. 915B441001 PVIP Mitsubishi DLP TV Bulbs
What is wrong with my Mitsubishi Tv model WD-65638
Youre lamp has failed. you need a new lamp.http://projectorlamps.com/mitsubishi-dlp-tv-bulbs-915b441001-pvip.html 915B441001 PVIP Mitsubishi DLP TV Bulbs
60 inch mitsubishi comes on no picture only sound and then it will turn off by its self
Most mornons seem to think that your TV is a traditional crt projection when in fact it is a DLP projection set and does not have convergence chips or CRTs. Instead, your set has a DMD chip and a projector lamp that passes light through the light engine where a color wheel is and the DMD chip itself. Often times DLP TVs cycle on and off again when the lamp is starting to go out. Mitsubishi is well known for this. However, it can also be a symptom of the color wheel going bad as well or simply updating the software by downloading it from http://support.mitsubishi-tv.com/
Good luck and rate me when you can.
My 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
