SOURCE: tv stuck in standby
I believe these Sony TV's have a built in obsolesence and Sony does not care about fixing them. I don't think a 7-year old TV is an "old model". Who can afford to by an expensive TV every 7 years. Shame on Sony.
SOURCE: Cant tune my Hitachi TV
please check web site for any thing in remote. www.remotes.com and give model name in search. hopr this will help. good luck.
SOURCE: RCU410wms RCA Remote
I've got this remote, and the instructions. The "Code Search" function will get you there, but it's tedious.
Step 1: press and release the "TV" button (top right corner)
Step 2: Press and hold the "Code Search" button (small triangle directly below the on/off button) for 4 seconds until the red LED lights up
Step 3: Point the remote at the TV and press the on/off button slowly -- here's the tedious part -- for up to 200 times. Each time you press the button, it tries a different remote code.
Step 4: When the TV turns on for you, press the "Enter" button (right side, just above the channel/volume keys)
Step 5: You're all set!
Or, if you're like me, there's a step 3a: press the on/off button to quickly, and hit blow right past your TV's code before you notice. If you do this, hit "Enter" and start over, going more slowly this time.
SOURCE: How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
chris
SOURCE: RCA remote instructions for Sony Cable TV
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH.
3. Press and release the device button for the device you are programming (TV, VCR or DBS•CABLE). The INDICATOR LIGHT will blink once then remain lit. DVD codes are programmed under the VCR button. Note: For AUX, press DVD•AUXthen the device button you are assigning to DVD•AUX. 4. Press and release ON•OFF until your device turns off. Important: You may have to press ON•OFF up to 200 times.
5. When your device turns off, press the ENTER button, the INDICATOR LIGHT will go off
