Hey Anton,
try one of these guys,,
http://www.watchrepairsusa.com/Pierre-Cardin/watch-repair
Servicing Pierre Cardin Watches
Pierre Cardin Watch Repair
SOURCE: pierre cardin running fast
Not enough information. Mechanical or Quartz for starters. Runs fast probably means it needs cleaning and service. Probably not a watch worth doing that with. They use cheap movements that can easily replaced but jewelers are too lazy or expensive to take a cheap watch to. These use cheapo movements.
SOURCE: how can i unlock the combination lock on my
If its a padlock your talking about a quick answer is try making a shim.
( http://www.instructables.com/id/Open-Any-Padlock/ )
a long answer is start at 1 and work your way up. lol
SOURCE: I need a spare part to my Pierre Cardin watch. Is
mcdevito75 here, You can try to contact online at Pierre Cardin watch.com Most likely you"ll have to send the watch to Pierre Cardin or you may be able to order the part you need.
SOURCE: Help! I own a Pierre Cardin
mcdevito75 Here, Hello Graham, yes the case of your Pierre Cardin watch can be fixed, Best Bet is to look for a small watch repair shop in your area, they can send your watch out for replateing. They may have to send your watch to Pierre cardin for this service.
SOURCE: bought a [pierre cardin necklace
Yikes, that's no good at all, you are first going to want to contact Ryan Air, their number for Ireland is 0818 30 30 30.
They will be the ones that connect you with Pierre Cardin if need be, but I would bet Ryan Air will correct the issue, I believe they are the ones who place the guarantee, plus it's a local call for you from Ireland, so that's DEFINITELY your best bet.
Thanks
Tim
