Question about Hawking Hawkin HiGain HWREN1 Wireless300N Range Extender repeater (S7232138)
This particular Hawking device must be configured after it is connected to your LAN and powered up.
Before you can do this, you will need the software from Hawking. If your devices Serial Number begins with HEMCHWREN1 use the link below"
http://hawkingtech.com/products/downloadfile/114.html
If you have a Revision 1 device with a Serial Number begins with HEMCREN1R1 use this link:
http://hawkingtech.com/products/downloadfile/117.html
Once you have the software, here are the steps you need to follow:
electrical source, and then connect it to the
'Power' socket of the Range Extender.
port on the Router or AP that you would
like to extend (repeat) the range on.
located on the back of your router/AP.
When the auto-load page appears, click the Setup Wizard option on the right and follow the Setup directions.
Scan for your Range Extender by clicking the 'Search' button. Once found, click the device to highlight it and click 'Next".
Choose a name for your Range Extender. You will use this name to identify and connect to your extended network. Optionally, you may change your login username and password. Click 'Next'.
At this point, the Setup Wizard should automatically obtain a new IP address for your Range Extender from the Router. Please wait for this IP to generate into the IP address field. Note the new IP address and click 'Next' to continue.
In the Search box, find the Wireless Network that you would like to extend. This Range Extender works best with other wireless-N networks, but also supports wireless-B and G networks as well. Select your preferred network and then click 'Next'.
For Security Settings, you must make sure that the Range Extender's security settings are identical to that of the Router/AP that is having the signal extended. If you do not know these settings please contact your network administrator.
At this point the Setup Summary displays all configured settings of the Range Extender. If the information displayed corresponds to your desired networks settings, you can go ahead and click 'SET' to apply the settings. The HWREN1 will automatically reboot. Please be patient.
More information can be obtained on the hawking site:
http://hawkingtech.com/products/hi-gain_wireless_networking/range_extenders_&_repeaters/hwren1.html
Posted on Jun 12, 2014
Oct 19, 2014 | Car Audio & Video
Dec 26, 2013 | Vertex Radio Communications
May 18, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
Sep 14, 2010 | Coby MP620 MP3 Player
Aug 08, 2010 | Audio Players & Recorders
Sep 05, 2009 | Sherwood RX-4109
Jun 28, 2009 | Olevia LT32HVM 32 in. LCD Television
Apr 21, 2009 | Lexmark X7350 All-In-One InkJet Printer
Mar 03, 2008 | Centrios EDW8020 DVD Recorder
Feb 16, 2006 | Linksys (WRT54GC) Router
190 people viewed this question
