Measuring Tools & Sensors Logo
Gladys Relland Posted on Sep 23, 2011
Lost instructions for my ACU-RITE model # 1097B MAIN wireless thermometer and need to reset it.
robert brown
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 15, 2014
robert brown
Contributor
Level 1:
Answers
Questions
0
Helped
1236
Points
0
I have a acu-rite weather station and it keeps blinking even after changing batteries, is it garbage now or can it be saved
1 Related Answer
Anonymous
  • 17 Answers
  • Posted on Oct 21, 2010
SOURCE: my acu-rite wireless thermometer model #00604RX
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
AcuRite Remote Sensor 00605TX for Acu-Rite 75321A1 Weather Station. I can't get my 00605TX to reset.
Question edited for a LOT more clarity. full 'make model (what it is)'.
Question moved from Computers to Model category.
Remove the batteries from both indoor and outdoor unit. Leave them out for 10 minutes. Replace the outdoor sensor with a new battery (2xAA), and then new batteries in the main unit (3xAA).
00605 Wireless Weather Station + Companion Instructions
AcuRite https://www.acurite.com > media > manuals > 0... PDF NOTE: When replacing the batteries for the wireless sensor, remove the batteries from the sensor and clear that sensor's channel on the main unit by pressing ...
6 pages
Hard Reset for Sensor Models 00606TX/06009RMA1 & ...
AcuRite https://support.acurite.com > en-us > articles > 360007...
The following reset steps can be performed to correct issues of the sensor not connecting to the display. Symptoms of the sensor not...
https://fccid.io/RNE00605TX/User-Manual/User-Manual-707183
ACU RITE Wireless Thermometer Model L5C0668TX cant set the date
I have misplaced the user manual for the
Acurite L5C0668TXACU RITE Wireless Thermometer Model L5C0668TX. Where can I get another?
2helpful
How do I reset the time on my acu-rite model # 604rx
Hold the Time button until the hour blinks. When it does, use + or - to adjust. When correct, press Time again. This will cause the minute to blink - use the same buttons to adjust. When finished, press Time again.
I need to reset the time and do not have the instruction manual.
I Have a Acu-Rite Acurite Wireless Weather Thermometer 604RX and it came without an instructions for use. Is there any web site I can go to in order to get the instructions or could you e-mail them to me? Thanks, Pat
3helpful
2answers
5helpful
I need a manual for an acu rite 00754 wireless thermometer. Where can I go?
http://www.partshelf.com/acu-rite-instruction-manuals.html
2answers
18helpful
2answers
Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Top Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
