Refrigerators Logo
Posted on Sep 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wine cooler has power, light is on, but is not refrigerating?
Anonymous
Level 2:
President:
  • Expert 3,773 Answers
  • Posted on Sep 26, 2011
Anonymous
Expert
Level 2:
President:
Answers
3773
Questions
Helped
609200
Points
163
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Uline wine refrigerator won't get cold
how old is it thay usely last a year or so set it tovery cold
Have a CVKG581 Wine Cooler and it is not getting cold. Light goes on so I know power is getting to the cooler
HI,CHECK THE COOLER TEMP CONTRL ,CHECK THE COMPRESSOR AND CHECK THE EVAP MOTOR ,,ANY OF THIS COMPONENTS MAY BE BAD..GOOD LUCK..
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Wine cooler just stopped working. light will come
Try disconnecting all power to the unit for about 10 mins, and turn it back on to see if the compressor will kick in. Also check your temp settings and make sure they are properly set. If that doesnt work, you might have a dead compressor which a tech can look at and verify.
DrakeTech.
Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
1helpful
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
