Question about Jabra BT650 Bluetooth Headset Halo
Jabra halo wont turn on or charch anymore...I've had problems with charging before and the charger it came with wont charge it but my phone one will sometimes.
Posted by gilbertjande on
5 Related Answers
Thieu-s
SOURCE: Jabra JX10 Bluetooth doesn't/won't charge
There is a way to fix this problem but i ain't easy...
The JX10 has a pretty dumb intelligent charger, it won't charge the battery when it's below a certen voltage so you have to temporarily "boost" the battery for the charger to pick up the charge process again...
You have to open the front cover of the JX10, peel out the battery and remove the tape from the battery to reveal the battery connectors.
When the silver foil plate connectors are visible you have to connect the charger and then connect 3 double A battery's (taped together or something) (total 3.5 volt) with the foil connectors for just 5 seconds. Mind the polarity! When you do this you will see after a couple of seconds the red charging light will lid! When the red light is on, disconnect your home-made "boost battery's" and the charger will charge the battery again!
It's a pretty hard job becouse of the tiny parts but is't worth the try...
And remeber to charge at least every month or you have to do this trick again!
Posted on May 19, 2011
Anonymous
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
Anonymous
SOURCE: new jabra 350 can't be charged
Make sure your adapter isn't in upside down. It fits both ways.
Posted on Sep 08, 2008
Anonymous
  • 4 Answers
SOURCE: Jabra bt250v Indicator light doesn't remain on...
i have just repaired my bt250 with this problem, i hadn't used it for around 2 years and when i put it on charge just got i flash of blue led. the fix was to "jumpstart it" the headset needs to se some sort of battery voltage to start the charging process, i stripped mine right down but that was just to fiddley. IF YOU DO THIS IT WILL BE ENTIRLEY AT YOUR OWN RISK AND I TAKE NO RESPONSIBILITY IF YOU TRASH YOUR OTHERWISE USELESS HEADSET. ok all you need to do is very carefully remove back cover (undo 1 screw and ease it apart). be very carefull as there are delicate wires inside. lift the inner part out slowly and you will see the battery.it has some orange tape around the end and there is a small circuit board attached to it with a small red wire and a small black wire. look at the battery and you will see under the orange tape there are to larger tags.these are the main battery terminals, peel back the orange tape just until the tags are slightly exposed. now you need to solder a wire to each of them and DON'T TOUCH THEM TOGETHER. on the battery it says which tag is + and which is - make sure you mark your wires or get red and black ones. now i used the lead from the charger. look at it . it has a hole in the center of the pin that is the + so put the + wire in there. if you are not sure use a volt meter. now touch the - wire to the outer metal of the connector that is the - point on the charger connector. hold this for around 2 mins but no more. as the out put of the connector is 6.2v and the battery is only 3.7v the battery will get warm. if the battery is getting too hot in under 2 mins then take of charge. when you have done that and taken off the connector i recommend to use a volt meter and just put it on the battery wires you soldered on to check battery voltage. as long as it reads you should be ok. de solder your wires from the tags and rebuild headset then try and charge it. this worked for me. i am no electronics expert i just like to mess with broken stuff so i know it seems a bit dodgy to connect like this but i had nothing to lose and it worked.
Posted on Dec 01, 2008
Anonymous
  • 6 Answers
SOURCE: My Jabra 2050 light does not stay on anymore when
http://www.jabra.com/Sites/Jabra/ap-en/headsetsupport/pages/Knowledgebase.aspx?kbid=784f9d0d-17f0-46fc-885d-dd402b7e7aae
maybe that can help?
Posted on Mar 25, 2009
My sms dongle says it's charging or charched.. but wont turn on after I unplug it from the charger
Replace the battery, or make certain the charger is charging. Does the dongle get excessively warm or hot
May 06, 2015 | Cell Phones
How to get new batteries for jabra bt2050
    • 1 Unscrew the small screw in the center of the Jabra's body.
    • 2 Slide the body to the left until it slips off.
    • 3 Unclip the existing, old battery.
    • 4 Clip the replacement battery into place.
    • 5 Replace the cover and the screw that held it down with the screwdriver.
    • You must charge the jabra headset's battery and go through an easy setup process before use.
Apr 27, 2012 | Jabra BT2050 Bluetooth Headset
Hi, i've had my Samsung genio touch for over a year now and i've had no problem untill now, the phone will not charge up, i've tried putting the charger in a different socket and taking the...
a possible battery or charger problem.
check if you can charge using a diff. charger,if you can?then the charger is the problem,replace it.
but if you can charge w/a diff. battery?replace the battery. :)
Sep 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Just bought jabra halo and am chagrinning it it has been 2hrs and it the red light is still flashing or is just not on at all what do l do
how long does the manual say to charge it for? usually it's several hours before you can actually have a full charge on the first use
Aug 11, 2011 | Jabra BT650 Bluetooth Headset Halo
How do I pair it with my phone? i lost the manual If I just turn it on, it my cell doesn't seem to find it. It says to put the Jabra in discovery mode. How do I do that? Also, do you know how I can...
Christine,
To put the Jabra in discovery mode, turn it on and hold the answer/end button for five seconds until the bluetooth light starts flashing and it announces "pairing mode." Then connect with your cellphone!
You can order a new charger for your car/computer from this link:
http://www.buyjabra.com/US/accessories/universal-charging-kit-car-usb-136.html
Or, for your wall from this link:
http://www.buyjabra.com/US/accessories/us-wall-charger-for-bt530-jabra-halo-144.html
Best of luck!
- Zach
Mar 05, 2011 | Jabra Cruiser InCar Speakerphone Black
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
NOKIA 6600 wont charge and turn on
hey,
how about check your charger .. maybe there is a problem with your charger... try another nokia charger
Cheers
Aug 28, 2008 | Nokia 6600
Phone charging
if you have a correct charger then the problem might be in your phone. i request you to give your phone to an authorised dealer. because the charging point in your might have broken or bent.
Jan 06, 2007 | Sony Jabra Earbud Headset - Ericsson T610...
Jabra BT650 Bluetooth Headset  Halo Logo
1,027 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Ekse
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
