Dell Studio 15 Laptop Logo
Posted on Sep 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dvd will not eject with button, but will if i go to my computer and go to d drive right click and eject.
robert_welsh
Level 2:
  • Expert 85 Answers
  • Posted on Nov 29, 2014
robert_welsh
Expert
Level 2:
Answers
85
Questions
Helped
13200
Points
138
It sounds like the DVD drive button is damaged or faulty - I would just continue to use the eject from the Windows,explorer window or have the drive replaced.
5 Related Answers
Anonymous
  • 114 Answers
  • Posted on Mar 31, 2009
SOURCE: A cd is stuck in my Dell Studio 15 laptop
Hello there,
find a very little hole infront and get a pin about 3-4 inches long and stick it there the CD drive should open, it will be a little hard but push it and it will open.
Anonymous
  • Posted on Apr 10, 2009
SOURCE: Dell latitude d505 - Cd drive eject button not working
Sniff My *** *****
Anonymous
  • 14 Answers
  • Posted on Dec 25, 2009
SOURCE: I have dual cd / dvd drives on my desktop
your cd drive might just be jammed. on the front of the drive there is a little pin hole. find yourself a safety pin or paper clip and insert it in the hole. push the pin in and it will unlock the drive door. with the door open restart your computer.
dont forget to rate your helper
Danilo Gonzaga
  • 356 Answers
  • Posted on Jun 03, 2010
SOURCE: dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
jd83854
  • 305 Answers
  • Posted on Aug 22, 2010
SOURCE: Hi, I have a Dell
Take a paper clip and straighten it. Easy goes - insert it in the small hole in the tray, just a little at a time. When you start to feel resistance, gently push a tiny bit more, and the tray will open. But do remember - be careful, don't just jam it in or you may damage your DVD as well as your tray. Sounds like you may need to have a new drive installed.
1helpful
DX4300-150
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
My MSI GT660 Dvd will not open or eject
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
1helpful
Disc Drive
If the eject button is not working, assuming this is a Windows based computer, click on start icon, your start menu will display, on right side under your user icon you should see Computer or My Computer, click on it.
You will now see all drives in your computer. Right click on your dvd(optical) drive. You should see an eject option.
If this dosen't work, close to the eject button on the drive is a tiny hole that will accept a paper clip, carefully push clip into hole until drive ejects.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Unable to insert DVD in DVD drive. Cannot locate eject button.
goto my computer, right mouse click on your dvd drive. click eject from the dropdown menu
Where is the EJECT BUTTON on mytwo year old model # PP25L Dell Windows Vista laptop computer
If there is no physical eject button on your dvd drive, you can eject it with your operating system.
Go to My computer and right-click on your dvd drive. Your dvd drive should eject.
Dvd will not eject from slot drive of dell vostro 1510
1helpful
Where do I find the eject key to eject a cd from my Dell studio laptop?
There should be a button on the DVD/CD drive itself, just push that small button and the tray should eject.
If you can't fine the button double click on "Computer" or "My Computer" highlight the DVD/CD in the list, right click on the DVD/CD and select "eject" from the list.
The tray should now eject.
Regards.
2answers
The tray won't open
You can eject from My Computer open it right click your dvd drive right click and select eject or you can insert a pin (sewing needle or safety pin) into the tiny pin hole near the eject button and push lightly this will eject it as well.
2helpful
I have a laptop that doesn't have eject button for slot cd player
go to Dektop / My Computer
right click
u will c all the drives....i mean..... c: d: etc
locate ur CD/DVD rom drive,..letter...d: or e: etc..
select ur CD/DVD rom drive
right click and chose option Eject...
u r set...
2helpful
2answers
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
