You can Unlock it using the Unlock code,You can get the Unlock code at here Warning : Do not
enter any wrong unlock codes on your Sidekick ID mobile phones. If you
enter over a certain amount of wrong unlock codes on your Sidekick ID
mobile phone, your phone may get hard locked and sometimes become
unusable.
Classicunlocking.com
and UNLOCK it step by step following instructions below:
Sidekick ID Unlocking Instructions
1. Switch ON your Sidekick ID with a Not ACCEPTED SIM Card.
2. If your Sidekick ID asks for a PIN code, then enter your SIM card PIN and press OK.
3. Sidekick ID will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your Sidekick ID is now unlocked.
Try code from service provider....................
SOURCE: unlocking a sidekick iD
1. Insert your non-TMobile sim card 2. The phone display says "Enter the code". 3. On your Sidkick, press the "X" button. 4. You will see the menu. 5. Choose the left-up angle button. 6. Choose "setting"--->"network"--->"scan and select manually". 7. The phone will search for your network. 8. When your Sidekick finds your network, you can use the phone to make calls
SOURCE: unlock code
just reset the phone and the passccode should be off but u will lose contacts pics text messages for a while all u have to do is remove the back cover hold R while holding it just remove the battery then place it back in while still holding R when u put the battery in stop pressing R an it will reset
