SOURCE: resetting fulbond wireless AP
problem solved when im using access point manager to accessed my wap.
the default password is "default". for unknown reason the wap seems cant be access thru http, even i enter the right password. the http page tell me that the password is wrong. But when i used access point manager from www.teletronics.com i can log in to the wap and configure it using the same password that i used on the http page.till now still dont know what's wrong with the wap.
since it's working fine im not trying to find out anymore.
the default password is working too on telnet and others but it still dont work on http page and i dont
see any configuration that restricted access to the wap thru http access.
SOURCE: I have a set Motorola
You need to user an Override Plug, which can be fabricated this way:
To fabricate an override plug:
1. Install an RJ-11 6-pin connector onto a 6-inch length of CAT 5 cable.
2. Pin out all 6-pins.
3. Short (solder together) Pins 4 and 6 on the other end. Do not connect any other wires to
anything. The result should be as follows:
Pin 1 ? white / orange ? Pin 1
Pin 2 ? white / green ? Pin 2
Pin 3 ? white / blue ? Pin 3
Pin 4 ? green ? Pin 6
Pin 5 ? blue ? Pin 5
Regaining access to the module
To use the override plug
1. Insert the override plug into the RJ-11 GPS sync port of the AP.
2. Apply power to the module through the Ethernet cable.
RESULT: The module reboots with the default IP address of 169.254.1.1,
password fields blank, and all other configuration values as previously set.
3. Set passwords as desired.
4. Change configuration values if desired.
5. Save the settings.
6. Remove the override plug.
7. Power cycle the module.
You can view more details at:
http://www.canopy-wireless-solutions.com/AppicationNotes/APManualIss5.pdf
restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds.
You will lose all of your personal settings if you restore the factory default settings.
You might need to do this if you are unable to access the Web User Interface or have forgotten your password.
hope this helps
Follow these steps to delete the current configuration and return all
access point settings to the factory defaults by using the MODE button:
1. Open the access point cover
2. Disconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. Press and hold the MODE button while you reconnect power to the access point.
4. Continue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. After
the access point reboots, you must reconfigure it using the web browser
interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
access point settings to factory defaults using the web browser
interface:
1. Open your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. Enter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. Enter the username Cisco in the User Name field.
4. Enter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. Click System Software. The System Software screen appears.
6. Click System Configuration. The System Configuration screen appears.
7. Click the Reset to Defaults button.
Note If the access point is configured with a static IP address, the IP address does not change.
