Repair BenQ Q24W5 monitor - Computers & Internet
Anonymous
    Novelist:
  • 132 Answers
HIIIIIIIII...................
Repairing BenQ 17′ LCD Monitor
I came across a common fault problem in BenQ 17′ LCD Monitor. The problem is have power but no display. Once you has opened the LCD cover, check the pico fuse for open circuit (very common), the push pull transistors C5707 for short circuit and the Buck royer circuit p-channel fet FQU11P06 also for short circuit too. For your information, if you can't get the FQU11p06 you can always use FU9024N as a replacement. Resolder all the high voltage transformer pins and replace the components above and I'm sure you will bring back the life of this BenQ 17′ LCD Monitor.
You may go to this fairchild semiconductor website to download the spec of the FQU11P06 P-channel FET.
http://www.fairchildsemi.com/ds/FQ/FQU11P06.pdf
GOOD LUCK............
Posted on Sep 23, 2011
1helpful
What's the weight of the Benq q24w5 monitor only? Without the stand? I have to attach it to an arm. Thanks!
use a scale, use postal scale, ask friends for one to use.
gee easy, no?
or google the manual
Benq q24w5,
typed wrong BENQ is one word
then the model is (that too typed wrong by you, ouch)
FP241W
goggle 1st hit shows, 10.6 kg or 23.3 pounds, (USA imperial)
sorry the books do not cover stand off weights. use a scale or subtract say 3lbs. to 20. (by seamans eye)
1helpful
BenQ Q24W5 LCD monitor circuit diagram
HI.............
GOOD LUCK.............
4helpful
3answers
BenQ LCD Monitor FP567, no display.The Green Led flicker,but no image.Please send us some tips
dreaded inverter board problem..here is a tip on where to look inside your lcd as is similar models...http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
BenQ FP91G+ Problem
Hi...there,
Dies on 1 seconds usually caused by busted backlight inverter or AC Adapter if you got one on your monitor.
Please help me fix this benq monitor
There are many posts that have solved this. Check em out
BenQ FP71E 17" LCD Monitor
Mail me what you need samir @viziks.com.
Samir
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Benq t701 flat screen no display
see this post
http://www.fixya.com/support/t155971-benq_t701_lcd_monitor
Computers & Internet Logo
Ekse
