Dell OptiPlex 170L PC Desktop Logo
Anonymous Posted on Sep 23, 2011
Display lines - Dell OptiPlex 170L PC Desktop
Anonymous
Level 2:
Novelist:
  • Expert 123 Answers
  • Posted on Sep 23, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
123
Questions
Helped
23047
Points
383
If there are lines in your monitor's display, the issue is either with the monitor or with your video card. In either case, a part is going to need replaced. Here are two ways you can test this:
1.) Connect a different monitor to your computer. If there are lines showing on this monitor's display, you need a replacement video card. If no lines are displayed, then the issue is with your monitor. If you don't have access to another monitor to do this test, then...
2.) Connect a different computer to your existing monitor (this can be a laptop, too). If there are still lines on the display with a different computer connected to it, then your monitor is the issue. If there are no lines on the display, then your video card needs replaced.
I hope this is helpful and thanks for using Fixya!
Ariyo Ayomide
Level 2:
New Friend:
  • Expert 149 Answers
Ariyo Ayomide
Expert
Level 2:
New Friend:
Answers
149
Questions
0
Helped
24426
Points
441
Check your IDE or SATA cable and your memory
MY PRINTER SAMSUNG SCX-4512F IS IN RUSSIAN CAN ANYONE HELP ME TO CHANGE TO ENGLISH
Changing the Display Language and Country
Setting Language
To change the language that displays on the control panel,
follow these steps:
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) until "Language" appears
on the bottom line of the display.
3 Press Enter. The current setting appears on the bottom
4 Press the scroll button ( or ) until the language you
want appears on the display.
5 Press Enter to save the selection.
6 To return to Standby mode, press Stop/Clear.
Setting Country
of the display.
2 Press the scroll button ( or ) until "Select Country"
appears on the bottom line of the display.
4 Press the scroll button ( or ) until your country appears
on the display.
NOTE: Changing the country clears the memory.
Link to manual
http://h10032.www1.hp.com/ctg/Manual/c05786751
I NEED TO SET UP 4 PHONES TO HAVE A LINE 5 AND A LINE 6. THE BUTTONS FOR THE EXTRA LINES ARE PROGRAM WITH SOMETHING ELSE. HOW DO I PROGRAM THE PHONES TO HAVE LINE 5 AND 6.
Programming is done on M7310, M7324 and T7316 sets.
To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the next key (bottom right arrow) till it says 025(or 031):unaaign press the chng key till the screen says appear&ring
Press the next key(bottom right arrow)
The display should say line 026(or 032): unassign
repeat the procedure the same as line 5 for line 6
press the release key when finished
5helpful
How do i make all lines ring at certain desks for a norstar m7324 phone?
Programming2_bing.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
3helpful
How to set up restrictions through line restriction filters
It's best if you use the "reply to post" window below the solution box so you can continue the same thread with the same person.
To set up the restriction filters we'll need to get into programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
At the terminals&sets prompt, press the next key (bottom right arrow).
The display should now LINES.
The display should now ask for a line number.
Enter line number you want to change the line filter on. ex. 002 = line 2
The display should say Trunk/Line data
Press the next key 2 times (bottom right arrow) .
The display should say Restrictions.
The display should say Restriction Filters
Enter in the restriction filter 25
The display should say No Restrictions and the ADD soft key should appear on the lower right soft key
Press the add soft key and in the restrictions you want on the line.ex. 011any will bolck int'l dialing but not long distance. 0any and 1any will block long distance, operator assisted calls, and int'l dialing
You can also add overrides by pressing the show key (top right arrow) then the next key (bottom right arrow) .The display should say no over rides and the add soft key should appear on the right soft key.
When finished with the filter press the heading key(top left arrow)
Press the next key (bottom right arrow) .
The display should say Line restrictions
The display should say Normal:none
Press the change key and enter 25.
Press the heading key (top left arrow) til the display says Lines.
Press the back key (bottom left arrow)
The display should say Terminals&Sets
Enter in the extension number of the person you want to allow free use of the line.
Press the next key 4 times(bottom right key)
Press the next key 2 times(bottom right arrow)
The display should say Line/Set restrictions
The display should ask for a line number.
Enter in the number of the line that was restricted.
The display should say Normal: none
Change the filter to 00 (no restrictions)
That bypasses this extension from line filter 25
Press the release key when finished
You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop. How though?
Changing programming on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) - display should read "lines"
4.- Press "SHOW" (top right arrow)- display should ask for a line number
5.- enter in the line number you wish to change the supervision on in a 3 digit format. ex. line 1 = 001
6.- press the show key (top right arrow)
7.- The display should say Trunk/line data
8.- Press "show"(top right arrow) - display should read "trunk type"
9.- Press the next key (bottom right arrow) 7 times"
10.- the display should say "trunk mode: unspr"
11.- Press softkey "CHANGE" to "super"
repeat steps 5 - 11 for the remainder of the lines Press the Rls key when finished
THE PHONE FLASHES BUT DOES NOT RING? We had a power cut the other day and since the phones have not rung, just flash? Anyone know why? We have 3 lines coming into the building. The lines have all been...
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
If your system uses the older programming template,
then Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
the display will say1. trunk/line data
the display will say 2.line access
the display will say line assignment
Press the next key 2 times(bottom right arrow) .
The display should say ringing.
Press the show key (top right arrow).
the lines should be listed as appear only change to appear and ring
press Rls when finished
1helpful
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
AVAYA PARTNER ACS PHONE SYSTEM - Separate Greeting
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#206"
the display should say Group Call Distrib Group:
Press 7 It will then ask for a line number
enter in 05
the display will say 1 assigned
press 3 VMS Line Cover
Do the same procedure (from #206 on) for line 6
Then enter #208
The display will say Line Coverage Ext Line:
Enter 05 The display will then say Data --
Enter in the extension you want the voice mail to pick up the lines on
Lastly if its not done allready, enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone thats getting the voice mails
The display should say 1 Assigned
press feature "00" to logout
1helpful
I need an extra line to ring on my phone
First, you'll have to know what the line number is in the system for the new line.
To get the line port number, on the set/s that the new line appears on press feature *0 and the the new line.
The display should say for example L025:LINE 05.
The port number of the example is port 025.
write the port number of the new line down for future reference.
Programming2.gif is done on M7310, M7324 and T7316 sets.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should say line 001: appear& ring
press next key (lower right arrow)til you see the line port number you wish to program
The display should say line 0xx: appear only
1helpful
Can I see the difference
Visually, there is very little difference to the eye of the average consumer between 720p and 1080. However, 720p can deliver a slightly smoother-looking image, due to the fact that lines and pixels are displayed in a consecutive pattern, rather than in an alternate pattern.your tv is display format is 720p and blu ray is 1080p. what happen is it will be scaled into 720p. old tv set format is 480p 720p represents 1,280 pixels displayed across the screen horizontally and 720 pixels down the screen vertically. This arrangement yields 720 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another. 1080p, on the other hand, represents 1,080 horizontal lines displayed sequentially. This means all lines are displayed during the same pass. 1080p is the highest quality HD display format. 480p represents 720 pixels displayed across the screen horizontally and 480 pixels down the screen vertically. This arrangement yields 480 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
