Computers & Internet Logo
Posted on Sep 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need some help pleas my harddisc keeps blinkin whats wrong its not workin
Anonymous
Level 2:
  • Expert 149 Answers
  • Posted on Sep 23, 2011
Anonymous
Expert
Level 2:
Answers
149
Questions
0
Helped
92884
Points
293
There are several types of damage to your hard drive
1.
When the computer is turned on, audible sounds, from hard drive. See the video and
This means, your hard drive optical is damage (heavy damage on the hard drive)
2. Hard drive not detect.
When the computer is turned on, a message appears "Disk boot failure, insert system disk ...." - see the i need some help pleas - abdulkarimap.jpg
Solution :
Hard drive ATA
move the jumper from Master to Slave, or the other.
Move the serial cable, from ATA1 to ATA2. Or replace the serial cable
Hard drive SATA
Use a jumper, on the hardi need some help pleas - abdulkarimap_3.jpge SATA
Move the SATA cable, from SATA1 to SATA2. Or replace the SATA cable
3. Hard drive bad sector. To fix hard drive bad sector,
use the software HDD Regenerator Bootable CD. Create, HDD Regenerator Bootable CD, restart the computer and boot from Cd Room. To repair hard drive bad sector, see the video .
Ariyo Ayomide
Level 2:
New Friend:
Ariyo Ayomide
Expert
Level 2:
New Friend:
Answers
149
Questions
0
Helped
24441
Points
441
Format it with window 98 and later upgrade it with XP or VISTA, if it doesn't work buy another one
Mediaform AP 1001: Harddisc crashed. Does anyone have an idea how to prepare/record new harddisc; which software is needed?
Check out podnuts computer repair forum @ http://www.podnutz.com/forums/ for good answer and relevant info
1helpful
3answers
Voltas cassette ac error codes
Voltas VRF indoor unit E0 error code sho
I try to my console on and it does turns on for a second and then shuts itself off and blinks red. its not hot or anything and idk whats wrong with it. my only controller was dead could that be the...
blinkin red light usually means hardware failer the only 2 easy tricks to try that wont void your warrenty is
#1 remove the hard drive and boot it up without it and see if it boots and says no hard drive then shut it down and plug the hard drive back in if it works now then was just a drive error if it goes back to blinkin you have a bad drive.
#2 the fan test that also seems to clear any over heating or other blinkin light problems --- turn the ps32.gif off for 40 seconds by the switch on the back then hold down the eject button and flip the power switch back on while still holding the eject button and see if that clears it.
No sound and current read 0 amps reads 0 it is installed correctly it was workin before then quit the volt indicater started blinkin now the light is constant but no sound the volts reads 12.1
Check the fuse on the unit first, if fuse is good and you have power to the am you may have fried it. This is common when the speaker load is not adhered to prperly. Make sure your speakers are connected properly (2/4/6/8 ohms) and not exceeding the limits of the amp, this fries them 99% of this time.
Bluetooth
Try deleteing the device from your phone and try pairing it again. Also your Bluetooth may need a new battery or charging. they both have to have good signal to pair properly.
Harddisc failure to bootup
Your hard drive may need reseating.
If it still gives error hard disk not found then you have a faulty hard drive.
You need a new hard drive and then install Windows.
Grand Canyon Tech
Grand Canyon Tech
