Question about Crosley CR249TA Turntable
My Crosley Keepsake CR246 record player just arrived today. However, after setting things up as instructed in the manual, it does not play records correctly. The turntable spins, but when I lower the tone arm on the record it skims across the beginning and does not play the record properly. There is a tiny bit of sound in addition to static. What is going on here? Everything seems to be working properly otherwise.
Posted by blueskies420 on
5 Related Answers
Anonymous
SOURCE: CROSLEY SONGWRITER CD BURNER CR246
Do a search on ebay, a seller has the manual attached to their product description as of 2/18/08
Posted on Feb 19, 2008
4L60B4R1UM
  • 133 Answers
SOURCE: Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
Posted on Aug 08, 2009
Grubhead
Grubhead
  • 5700 Answers
SOURCE: I have a Crosley Keepsake turntable which plays 33
The only thing (I think) that would cause a 45 to play badly and the 33 not, is either the cartridge or stylus, most likely the stylus. It's either worn or damaged, so it fits badly in the larger grooves of 45's then the smaller ones of 33!
The signal coming from the cartridge is the same on 45 as it would be from 33.
Posted on May 25, 2010
Anonymous
  • 269 Answers
SOURCE: I just received the crosley keepsake usb turntable
If you just received it? I would return it. You have done everything i would have done. If its brandnew? I would deffinately return it. You don't want to void warranty.
Posted on Dec 26, 2010
bobhifi
Jacob Paul
  • 635 Answers
SOURCE: My Crosley CR246 makes a
Remove the cartridge head shell from the arm and reinsert it. You must be having a contact problem with the cartridge. ( loose connection )
Posted on Mar 10, 2011
HOW DO I ADJUST THE SPEED ON A CROSLEY CR47 RECORD PLAYER
There should be a speed control switch in the upper right side near the arm.
I found a CR-48 manual with a picture at page 4 at the link shown. That should be similar to the CR-47
Crosley CR 48 Instruction Manual Control Locators Getting Started
Jan 21, 2018 | Crosley Audio Players & Recorders
Crosley troubadour stops before record is done
Check to see if there is a switch setting for 7", 10", and 12" records. Sounds like a switch setting to me. Does it always pick up at the same physical location on any record? If so, that is the likely cause. Personally, if you have an extensive collection of vinyl, a Crosley is definitely NOT the best turntable to be playing them on. You'd get way better fidelity and save your records from physical groove damage by investing in a better turntable. If you want the collection to stay in good shape and retain their value, ditch the Crosley ASAP.
Dec 03, 2017 | Crosley Audio Players & Recorders
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
Dec 14, 2015 | Crosley CR8005A-TU Cruiser 3 Speed...
My crosley keepsake turntable has been having a lot of static and the sound is very low, I can only hear it if I turn the volume all the way up. I'm not sure if the needle is the problem or there is s
I would check the wires to the cartridge. It might that one or more is off or loose.
If you turn down the volume completely and listen with a record playing you should be able to hear (with your ear) the stylus in the grooves of the record playing the track. Pick a loud (rock) record for this. If it does that OK the stylus is good.
Dec 26, 2014 | Crosley Keepsake USB Turntable
I have a Crosley Keepsake turntable which plays 33 1/3 rpm records perfectly. However, when I try to play 45rpm records the sound is very distorted, especially the vocals which sound as though they are...
May 20, 2010 | Crosley 0187SST Turntable
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
Here is the entire manual that comes with the unit. www.crosleyradio.com/Manuals/CR246_Manual.pdf
Jan 06, 2008 | Crosley CR248 Turntable
Crosley CR249TA Turntable Logo
193 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
