NEO iGolf neo MP3 Player Logo
Posted on Sep 22, 2011
One of my function buttons popped off on the course and could not be found. where can i find this part ?
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
1helpful
Humax foxsat remote control problems went away on
Try factory reseting the remote control.
Can not get the thing out of demo mode read instructions no luck.
Look for the function button. Once found (on unit or remote), turn off the power. press and hold the function button until the units sub menu pops up. use this screen to set time and other options. one of the options is to turn of demo mode. At least that used to be how pioneer did it.
How to perform a factory reset on a Garmin GPSMAP 172
The model number of your unit has been cut off so I can't find exact instructions. I found a page here where the guy said he held down Enter and Page keys while turning the unit on.
http://forums.groundspeak.com/GC/lofiversion/index.php?t128887.html
You should be able to find the user manual if you do a google search. It will have all the details.
Try "Garmin Gpsmap <your model> manual pdf" as the search string. (no quotes of course)
Hope this helps
Aug 16, 2009 • Garmin GPS
Webroot spyware will not sweep
I was just using Webroot Window Washer the other day and had a similar problem. I went to the control panel and deleted the program. Then I reinstalled it and it worked fine this time. Of course I was using a free trial. If you purchased the program just download it again or reinstall it from your disc.
Erase picture question pops up constantly and won't go away!
I recommend taking the back cover off, and getting under the buttons with a lint-less cloth, and swab it off with a dab of alcohol. It could be that a button is stuck.  Of course, I would check all of the settings first to see if there is something to fix it there.
5helpful
Door panel removal of 2007 nissan sentra
theres a small panel behind the door lock and handle.
pop that off, and unscrew the screw found.
After that, it just pops off, and back on.
You have to disconnect all the wires, of course.
I had to pop them off to tint my windows.
2answers
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
E260 setting buton is no functioning Help
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Top NEO Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a NEO Audio Player and Recorder Expert? Answer questions, earn points and help others
