Question about Power Acoustik LT-980/2 Car Audio Amplifier
I have a power acoustik amp and have never had problems with it until now. on normal operation i turn my key then the amp shows red light then switches to green and powers the sub. but now i turn the key and it shows red light then turns off. Let me know what your ideas are. Jason
Posted by grifjd5 on
5 Related Answers
Anonymous
  • 37 Answers
SOURCE: Protect Mode
this is usually a problem with incorrect cabling you should check and see that all your cables are connected properly especially the ground cable thats what would normally give you a red light on your amp
Posted on Aug 05, 2009
Anonymous
SOURCE: protection light on
go to power acoustiks website at: poweracoustik.com then tech support look at how to insatll an amp
Posted on Jun 29, 2007
Anonymous
  • 5 Answers
SOURCE: 600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Posted on Oct 09, 2007
myearwood0
  • 93 Answers
SOURCE: amp light is neither green or red
have u connectted the remote wire from head unit to turn amp on? have u got + and - the rite way round.hope this of use.
Posted on Mar 05, 2009
Anonymous
  • 84 Answers
SOURCE: Power Acoustik Area 51 Amplifier
Make sure your sub is wired in bridged mode also and not to an ohm load that is too small for your amp to take. Such as a 1 ohm load or a .5 ohm load. A great way to figure this out is to go to Crutchfield and find their section on subwoofer wiring diagrams. Another good source is www.the12volt.com which also will show you all options. you must be presenting a 4 ohm load from your sub to the amp because it's smallest impedence is 2 ohm stable. Then you bridge at the amp which is 2 ohms to each channel you are trying to bridge.
Posted on Jun 13, 2009
How i do may my power acoustik play in my truck.power go off and on ?
red pos key on, yellow always pos,blue sends pos to external amp or power antennae if none tape up- black wire neg. the rest pretty much speakers.
Feb 03, 2015 | 1994-1998 Chevy C2500 Truck 10 Piece...
I have a power acoustik bamf 1600/4. not working 5 hours later
use a multimeter to see if the amp has good power wire and remote turn on voltage. then check the ground and make sure its a good strong ground. check the sub to make sure its not bad. make sure it reads whatever ohm its supposed to. anything less than 4 ohms will clip the amp if bridged. if alll that is good then the only thing left is the amp. it sounds like the power supply is bad but check everything else just to make sure. good luck.
Dec 29, 2009 | Power Acoustik BAMF1600/4 Car Amp
I had this amp set to LPF with the volume all the way up. I accidentally switched it to 'full' and it shut off. When it gets power now, It blinks the red light once. I checked my fuses and they are all...
Hello goodgawdz,
It's possible that when switched to amplify all frequencies, the amp drew excessive current and fried the outputs. It's also possible that the speakers were damaged. I'd recommend disconnecting everything except ground, power, and remote and see if the amp powers up normally. If it doesn't, the amp outputs are probably faulty. If it does power up normally, check the speakers and their wiring.
Nov 09, 2009 | Power Acoustik LT-980/2 Car Audio...
Protect Mode
Aug 02, 2009 | Car Audio & Video
Red light keeps flashing..
my kicker was doing the same thing, and come to find out the power was loose,
1.check power connection,
2. check ground
3. check remote wire.
4. check that your amp isn't mounted on -metal-
5. check your fuses onboard the amp,
6.check you speaker wire
7.check your rca jacks
8. check that your gains aren't too high for the wattage
May 12, 2009 | Power Acoustik PS2-1250 Car Audio...
Amp light is neither green or red
Mar 05, 2009 | Power Acoustik PS2-1250 Car Audio...
My "Power Acoustik OV2-420" has a problem. Some advice please!!!
It appears that the output transistors have failed. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 04, 2008 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Sep 20, 2008 | Power Acoustik TS620-2 Synchronized...
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Power Acoustik
the amp shouldnt even lite up w/o the ground attached.
Jan 25, 2007 | Power Acoustik GOTHIC OV2-520 Car Audio...
Power Acoustik LT-980/2 Car Audio Amplifier Logo
80 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
