GPS Logo
Question about Tomtom GO 510 GPS Receiver
Could you please tell me where the reset button is at on the Tom Tom model number 4en52z1230
Posted by swilliard on
1 Related Answer
Anonymous
  • 4 Answers
SOURCE: Can you tell me where
I'm a little confused about which unit you have, but the answer is simple enough..... If there isn't a small hole on the bottom of the GPS, then simply hold the on/off button for approximately 15 seconds -- until the unit restarts. The small "hole" that I'm referring to will be in the same vicinity as the connector that the cable plugs into. It should say reset right by it, if the reset button is there. If you do have a reset button on the bottom of the device, you'll need to use something to press the button. A paper clip straightened out a bit works perfectly.
The following lists are from Tom Tom's website. I hope this helps:
Devices that are reset by holding the On/Off button ico_open.gif
(GO x50, Blue&Me TomTom, GO x40,
XL IQ Routes, XL,
ONE IQ Routes,
Rider Pro, Urban Rider)
(GO x30, GO x20, GO x10, GO,
XL IQ Routes ², ONE XL,
ONE 3rd Edition, ONE 2nd Edition, ONE 1st Edition
TOYOTA, ECLIPSE, DAIHATSU, ECLIPSE II,
Toyota Aygo Connect Multimedia,
Start ², Start
RIDER 2nd, RIDER 1st)
Posted on Apr 29, 2011
Tom tom xxl will not turn off or on its just got a white screen
To reset these models, just hold the power button in for 15 seconds.
My tom tom go stopped working. green light is on car cigarette lighter bit and on tom tom unit but screen wont come on it stays blank. it had just fallen off windscreen onto dashboard. memory card in...
Not sure which model year you have but check for a small reset button on bottom press and hold it with a paper clip or similar. Also try holding the power button for a minute to see if it reboots, try removing the memory card first. If it starts don't insert the memory card until the unit is off. If that still does not work click on the link below which will explain the reset in detail.
Thanks for using FixYa
http://www.ehow.com/how_5146905_reset-tomtom-go.html
Jun 02, 2011 • Tomtom GPS
2helpful
Tom tom will not turn on, but charge light works.
Please connect your tom tom to the power adapter first.Get a paper clip and press the reset button under the SD card slot of your tom tom.Reset button is a very small small hole at the back near the sd card slot.Keep pressing the reset button for 2mins and also press the power button till the light comes on.
This should fix the issue.Let me know if you need any more help.
Jul 08, 2009 • GPS
5helpful
4answers
How do I reset to factory settings how to reset factory settings on tom tom one
Which Model of Tom Tom One ?
XL
3rd Edition
2nd Edition
make sure you're fully charged, remove any optional memory cards (depends on the unit) there should be a reset hole, place a straightened paperclip into the hole and press for 15 seconds.
140/130/125
make sure you're fuly charged, press and hold the on/off button for about 15 seconds until the unit restarts
2helpful
Clearing my tom tom 700 of recent destination and phone numbers
Perform a hard reset. That should delete every last bit of info you have saved on your tomtom. To do this press and hold the power and reset buttons for about 5 seconds.
Regards,
Sai.
Ive wiped it
HI,
Try Hard-resetting the device.
Remove Memory-SD Card if Fitted.
Reset button. at the bottom or underside Of Tom-Tom ( Model Depending )
Use paperclip or cocktail stick. Push and hold reset For 10 Seconds.
Mike @ Compurepair.
2answers
Tom Tom 910 software
I don't think the Tomtom 910 has a SD card slot. Check the model # of your GPS again.
TOMTOM GO NOT SWITCHING ON
Hit reset button.
How old is the GPS?
Please give model and serial number to:
[email protected]
13helpful
6answers
Tom tom go 500 wont power up
Press the power button for 15 seconds and your tomtom will turn on with the drum sounds yor tomtom will now reset but nothing will be deleted off it and it will now hope fully work.
Bye
Open Questions:
See all Tomtom GO 510 GPS Receiver Questions
Top Tomtom GPS Experts
Marvin
Marvin
David Shaub
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
