Question about Xerox DocuColor 12 Color Copier
How to Solve the problem in Xerox DC12 ERROR 10-399???
Posted by ghallib on
L Pfaff
    Top Expert:
  • Xerox Master
  • 11,573 Answers
Posted on Jun 26, 2016
Jorge Luis
    Sergeant:
  • 198 Answers
Go to
http://www.support.xerox.com/support/docucolor-12/documentation/enus.html?associatedProduct=fiery-ex12
choose if I s Fiery, Splash
Select support and error codes
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Posted on Sep 23, 2011
Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . [email protected]
Mar 23, 2009 | Xerox DocuColor 12 Printer
Xerox DC12 system failure: code 10-361
I have found the Heating Tube 520 is dead, so the Roll doesn't hot enough. This problem was solved simply - by replacing the Tube...
Feb 11, 2009 | Xerox DocuColor 12 Color Copier
Eror code 3-380 System Fault problem
Whenever switchon my Dc12 The mahinc ready within 5 minutes and final stage it shows the eror like "System Fault" error code 3 -380 Switch of your printer and on. How can I solve it.
Oct 15, 2008 | Xerox DocuColor 12 Color Copier
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox DC12 System Fault 6-355
06 codes refer to exposure lamp problems..(or scan) check lamp coming on, scan carriage position etc, don't have the code list, so carefully move the scan carriage up and down, make sure it moves OK
Jun 05, 2008 | Xerox DocuColor 12 Color Copier
SERVICE BOOK
If you go to www.xerox.com and to the support and download area.
Type in DC12 in the search and then to downloads and drivers.
Select documentation and there is a variety of user support documentation to download.
Dec 13, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
358 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
