Canon LC-3175 Laser Fax Logo
Question about Canon LC-3175 Laser Fax
Cannon fax lc 3175 need to change header on outgoing faxes
Posted by wyattsawyer on
5 Related Answers
Anonymous
SOURCE: change phone number on fax
FAX PRINTS OUT OLD PHONE NUMBER. FAX NEEDS TO REFLECT NEW PHONE NUMBER ON SENDING HEADER OF FAX
Posted on Jul 12, 2007
checkitright
CheckitRight
  • 1363 Answers
SOURCE: panafax uf585
here is the manual
http://service.us.panasonic.com/OPERMANPDF/UF585.PDF
Posted on Feb 15, 2008
Anonymous
  • 287 Answers
SOURCE: Changing outgoing name on fax
the MANUAL should answer your question
Posted on Jul 16, 2008
Anonymous
  • 2120 Answers
SOURCE: Canon MP830 - Outgoing fax dialing not connecting
Are you plugged into the LINE port of the fax machine?
Posted on Oct 21, 2008
Anonymous
  • 2120 Answers
SOURCE: adding to an established Group Dial list
In most fax machines you cannot edit a GROUP, you can only delete it and create a new group.
Posted on Nov 25, 2008
Fax machine works good but I bought it at an auction sale and when you send a fax it has the former owner name and fax number on it. I need to change this info to my name & fax# and don't have a manuel...
To change the fax header from the front pannel:
Press Menu , then 7 , then 2 . Enter your fax number and name to be printed on all outgoing faxes. NOTE: In some locations this is a legal requirement. Entering text Press the keypad numbers corresponding to the letters you need. It will cycle through the lower case, then the upper case of each letter. Press the right arrow button (also the Speed Dial button) to advance to the next space. Example: Pressing number 2 once = a, twice = b, three times = c, four times = A, five times = B, six times = C, seven times = 2. *** You can get support for your printer (i.e., download drivers, software, manual an other documentation and access FAQs and How-Tos for your printer) from HP, here: http://h10025.www1.hp.com/ewfrf/wc/product?product=58854&lc=en&cc=us&dlc=en&lang=en&cc=us
How do I change the time on my Canon LC-3175?
Open all 3 One-touch Speed Dialling panels.
press Data Registration. press Set.
USER SETTINGS press Set
DATE & TIME press Set
use numeric keypad to enter month/date/year and then time press Set
To exit, press Data Registration or Stop
Need fax confirmation
Not an expert on this model however, on most canon fax machines the plastic cover or panel on the keypad is a door. Opening this you should see descriptions for the keys one should say report. Press report to print and follow instuctions to get activity report.
Hope this helps
Change fax number displayed on outgoing faxes
You need to go into your "Function" key- do you have the User's Manuel- if not you can go to canonusa.com- I am a USA Canon dealer so i can only refer you to the USA site, go here down load the User's Manuel- I haven't done it in a while but, i do believe you need to go into the Function mode the display "Set-Up" then change output preferences , I think your getting the " Sent " request- trust me get the User's Manuel and read it this should solve your issues you can download it right from the canon Website
How do i get a conformation when i fax with my canon LC-3175
You look in the manual and turn the feature on.
Don't have a manual?
Go to www.canon.com and download it
Adding to an established Group Dial list
Faxes in memory & will not print out
Unplug the power cord for 10 seconds
2answers
Manual for Canon LC-3175
Ever think of trying www.canon.com??
Maybe under "support <drivers/downloads>"....but I'm just guessing.
2helpful
2answers
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
old marine
old marine
Marvin
Marvin
