Question about Casio Exilim Pro EX-F1 Digital Camera
How can I make the focus ring work on my casio exilim ex f1?
Posted by twoos on
Steve
  • Casio Master
  • 3,289 Answers
The manual (pg 43) says that each time you press the FOCUS button, it will advance between Auto (AF), Macro (Flower), Infinity (Sideways 8) and Manual (MF). You can use the < or > keys to focus , or the ring if set up as described below:
Next, the focus ring can be programmed (pg 85) by pressing [REC] -> [MENU] -> [REC Tab] -> [Ring Setup]. Choose "CS fps" for Continuous Shutter Speed (pg 46), "Zoom" (pg 40), "Focus" (pg 43), or "Off" for no function at all.
You can download your manual here.
I f this was helpful, please rate it 4 thumbs up. Thanks!
Posted on Sep 22, 2011
The monitor screen will not come on the Casio Exilim EX-S770 digital camera. Can it be fixed???
Yes. It might be the back light or inverter. If we're lucky, it could be just a loose connection - it has to be disassembled.
Nov 23, 2010 | Casio Exilim Pro EX-F1 Digital Camera
I own a casio exilim ex-z850. it has been showing a lens error, every time i try to take switch it on. the memory card is fine, i view the pictures. but the lens wont open up or anything. please reply...
This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Sep 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
My Casio Exilim EX-Z80 wont turn on
The lens barrels are jamming someplace. wen the camera moves the lens out immediately pop out the battery so that it stays and then turn the zoom from the outer most barrel in the direction it comes out side. Do not force it too much. If that works fine other wise take it to the service center
May 01, 2010 | Casio Exilim EX-Z57 Digital Camera
Spanish manual Casio Exilim Pro EX F1
You can download the Spanish manual for Casio Exilim Pro EX F1 by clicking this link:
http://www.support.casio-europe.com/es/download/manuals/dc/EXF1_110_s.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Jan 30, 2010 | Cameras
Need usb cable to casio exilim camera EX-S10 what type of USB connector is on this camera, not mini A or B. thx
i f i remember correctly, this camera has input/output terminals. both for USB/AV port and a USB: high speed USB.
http://cgi.ebay.com/Casio-USB-cable-Exilim-EX-S10-S5-EX-F1-EX-Z100-150-200_W0QQitemZ120460169326QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item1c0bfc506e&_trksid=p3286.c0.m14
http://cgi.ebay.com/Casio-USB-cable-Exilim-EX-S10-S5-EX-F1-EX-Z100-150-200_W0QQitemZ110426500160QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item19b5eeac40&_trksid=p3286.c0.m14
Aug 31, 2009 | Casio Cameras
Exilim EX s600 lens grinding on extension
I had the same problem and I left it on the charger over night and in the morning I turned it on and the lens extended smoothly with no noise and is now focusing
Nov 14, 2008 | Casio Exilim EX-S600 Digital Camera
Casio s500 digital camera
This error indicate that focusing ring got stuck or jammed due external shock, liquid, sand & dirt etc. enters the camera.
  • What you can try to do is spray some compressed air into the lens area to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
Else your camera need to be disassembled to get at the focusing ring.
Mar 18, 2008 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-Z60 Start up and screen problem
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them.
Dec 15, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Exilim Pro EX-F1 Digital Camera Logo
311 people viewed this question
Top Casio Cameras Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Casio Camera Expert? Answer questions, earn points and help others
