Hi i just installed windows 7 and i am having trouble connecting wirlessly i hav a medion wim 2160
Posted by Jella Chand on
Art Ellison
  • 2,229 Answers
It sounds like you installed Win 7 on a computer you already have. If so, you will have to download the correct drivers for wireless, sound, video, etc. from the manufacturer.
Next, you'll need to be sure your wireless adapter is actually turned on. Sometimes this is a switch on the side of the computer and sometimes a soft-switch (Fn + special function key combo).
Posted on Sep 22, 2011
I have been given a medion scanner August 2002 and hoped to scan some old photos by using my new laptop DELL WIDOWS 7 HOME PREMIUM.no such luck.My laptop will not recognise or connect to it.I have followed...
Hi alistair49,
Firstly, is your laptop connected to the internet when trying to install your scanner?
Windows 7 will automatically browse Microsoft's online database of drivers if it's not found in your laptop database.
If you are in fact having driver issues, have you checked the following web page to locate your scanner software?
http://www.medion.com/gb/service/download/driver.php
If, however, you have the drivers, make sure that these are compatible with Windows 7 as your scanner was manufactured before Windows 7 existed. In this case try using Windows 7 compatibility wizard to install your scanner software.
You can do this by right-clicking on the installation file & selecting "troubleshoot compatibility" from the drop-down menu. Simply follow the on-screen directions step by step to check if Windows 7 has compatibility issues with your scanner software. In most cases this procedure should solve your problem.
Best wishes,
Graeme.
Mar 23, 2011 | Computers & Internet
How to increase brighness on medion laptop model WIM 2160
Hi
Thank you for your query
The easiest way to adjust the brightness is to press
fn + a key which has a sun like picture on it, on most laptops this will be the up arrow key to increase brightness and the down arrow key to decrease brightness
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | Medion Computers & Internet
I have a medion driver disc for windows 7 upgrade kit. When i try to install it no instructions appear just 7 programs : Chipset, Raid, TV Tuner, WLan, Lan, Sound & VGA how do I install windows 7 ?
Did this come with your computer or did you purchase it from somewhere? This doesn't install Win 7, just the drivers after the upgrade. If you purchased this cd, the drivers are only good for a Medion computer.
Dec 30, 2009 | Microsoft Windows Vista Home Premium with...
Hi there, Firstly, I've tried to search for this issue but no joy, but if I have missed it - then I apologise! Basically, I recently had to do a fresh install of Vista on a Medion WIM 2160 laptop. Ever...
before you installed vista, did you check to see if your laptop met the minimum standards for windows vista?
Did you check the mfr's website for updated drivers?
Nov 24, 2009 | Medion (40010998)
Good day, i dont ve sound in my laptop medion wim 2050
If your audio driver isn't correctly installed, then you can download latest audio driver here www1.medion.de/downloads/?lang=uk
Dec 09, 2008 | Medion md40298 Notebook
Medion MD41349
You need to remove all the screws from the back also, then remove the cover to the rear on the bottom and remove the wireless card (make note as to connection colours) and there is 2 (I think) screws under there, then one also under the battery, then the whole top opens up.
Make sure you have removed all screws from the bottom case, including the four under the rubber feet at the rear.
This was the most awful laptop I have ever worked on!
May 11, 2008 | Medion MD-40954 Notebook
Computers & Internet Logo
129 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
