Has the receiver gotten faxes
(from other senders) since your problem started? It sounds like the receiving
fax is not answering the call. Also to determine if it's your problem or
the receiver's problem send a test fax to someone else.
Maybe I was clear enough; you have to figure-out if the malfunction is at your end, or (more likely) at the receivers’ end. There are 2 steps to determine where the problem is.
1. Send a test fax to a different receiver.
2. Have the receiver (that you are having a problem with) get a test fax from someone else.
My suspensions are that your fax will go through but that the receiver (that you are getting this problem from) will not automatically answer no matter whose fax tries sending.
PHONE DOES NOT CONNECT TO THE RECEIVER. CANNOT SEND FAX
