Canon LC-3175 Laser Fax Logo
Question about Canon LC-3175 Laser Fax
Hello I need to change header for outgoing faxes
Posted by wyattsawyer on
  • 5 more comments
  • wyattsawyer Sep 22, 2011
    i DO NOT HAVE SET UP KEY NOR OPTIONS KEY OR ADDITIONAL FUNCTIONS KEY WE DO HAVE A MENU KEY,AND A KEY THAT SAYS ONLY SET ,ALSO A PROGRAM KEY ?,
    I DO NOT HAVE A FUNCTIONS KEY I HAVE A PROGRAM KEY
    WE DO NOT HAVE AN OPTION KEY ONLY A PROGRAM KEY OR A SET KEY
    Yes I have a cannon LC 3175 fax printer your invoice # 325222 I am trying to change header that prints on outgoing faxes this machine does not have a set up key or option key or additional functions key,it does have a set key,and a program key
    I have no set up key,also I do not have options key nor additional functions key this is a cannon laser class 3175
    hello you are the 3rd representative they dont seem to be looking at the correct model of fax when they give advice can you help
  • wyattsawyer Sep 23, 2011
    thanks
Carl Navarro
  • Canon Master
  • 2,460 Answers
Start in Chapter 3 of the manual http://www.procopyoffice.com/Manuals/LC3170/LASER%20CLASS%203170%20Series%20Users%20Guide.pdf On page 3-13 it describes how you press DATA REGISTRATION and enter the Transmit Terminal ID.
Carl
Posted on Sep 22, 2011
Anonymous
  • 957 Answers
1.Press the "Set Up" key. This will bring you into the set-up options for your fax machine. If your fax machine does not have a set-up key, look for either an "Options" key or "Additional Functions" key.
2 .Scroll through options to find "Transmission Options." This list will contain all of the options that you can set for your outgoing faxes.
3 .Select "Fax Header." Once selected, you will be able to enter in personalized information. Enter your business name, phone number and any message that you wish to add. Most fax machines have a character limitation that you cannot exceed.
4 .Press the "Save" button. This will save your fax header as well as any other personalizations or settings that you changed.
Oloyede Monsuru
  • 1,468 Answers
Hello.
Fax machines continue to serve a valuable function in many businesses and homes. Many fax machines allow for customizations that can help your sent faxes stand out from the rest. One of these customizations is a personalized fax header. A fax header is the information that is printed out on the very top of each received fax. Most senders include their fax number and business name but can also include personalized messages. Each fax machine differs in the set-up process, so be sure to review your owner's manual.
2 Scroll through options to find "Transmission Options." This list will contain all of the options that you can set for your outgoing faxes.
3 Select "Fax Header." Once selected, you will be able to enter in personalized information. Enter your business name, phone number and any message that you wish to add. Most fax machines have a character limitation that you cannot exceed.
4 Press the "Save" button. This will save your fax header as well as any other personalizations or settings that you changed
Please rate this solution .
Thanks.
  • Oloyede Monsuru Sep 22, 2011
    Hello.
    The functions are same .
    That's the set up key with your what you have on your machine are working in same directioN.
    Thanks.
    Hello.
    Please apply the opition key as your set up key to start soving the problem .
    Thanks.
Can you add a new fax no that shows in the header for outgoing fax?
To set Outgoing Fax Number/ ID follow the follwing steps: -
- Press FUNCTION, Press 7 (Set mode will appear on display)
- Press 1 (User Parameters Settings)
- Press Set repeatedly until display shows ID
- Enter your Number/ ID (max. 20 digits) by using the key pad
For further information you may refer to User Manual for Panasonic Panafax UF-585 Page 29
Hope it helps! Good Luck!
CreativeTECH
2answers
How do I change the name and fax number on the top of my outgoing faxes
The software that came with the printer will have a "setup" or "settings" icon. You can change it there.
If you can't find it or never installed it you can delete the printer software and re-install it and you can start from scratch with the new information you want.
3helpful
I need to change the name on outgoing faxes from my HP 6310 Officejet, but cannot find the information in the owner's manual. Can you help?
This "Fax header" information can be changed on the OfficeJet 6310 control panel:
1) Press the <Setup> button
2) Press 4, then press 1
3) Enter your personal or company name
4) Enter your fax number
You may have to use the numeric keypad to enter letters. The number of presses of the key changes the letter.
I hope this helps!
How do you set/change the outgoing phone number on an HP Officejet 6110?
Hit setup. Arrow to fax setup (4). Hit ok.
Arrow to fax header, hit ok. Enter name, ok. THAT should bring you to the phone number.
Change name that appears at the top of outgoing faxes
press Menu
press 5 then 2
select the "fax header" option
when your name appears, enter your name using the keyboard.
the keyboard is similar to cell phone keyboard.
press enter
enter the fx number when your are prompted
press enter when finish.
if you still haev problem, please click on the following link for HP Officejet6110 users' manual.
HP Officejet 6210xi All in One
You can actually change the fax header by following the steps:
1, Press on SETUP button on the printer, then scroll down using the ARROW RIGHT BUTTON;
2. Look for Basic Fax Setup, then press okay;
3. Under Basic fax setup, scroll down and look for FAX HEADER, then press okay.
4. From that option, it will allow you to change the informations for the fax header.
please let me know if the steps i gave to you is a big help.
thank you so much.
adonscott
2helpful
2answers
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Change phone number on fax
FAX PRINTS OUT OLD PHONE NUMBER. FAX NEEDS TO REFLECT NEW PHONE NUMBER ON SENDING HEADER OF FAX
old marine
old marine
Marvin
Marvin
